I have several avi files that are downloaded bittorrents. My problem is I can view them with the VLC Media Player and they look great, however any on other player I use or converter (to convert to DVD i.e. DVD Santa) the video looks all scrambled and somewhat digitized. Does anyone know how I can get past this and create either a DVD or Video CD from these files.
Also, when I move these files to my Creative Zen Vision M (I highly recommend this over the Apple Video IPOD) the files look great.
Any help is appreciated...
Start with g-spot 2.52b beta. Post a screenshot so we can see what you have. VLC has it's own codecs, so it doesn't rely on you having the right ones installed. Most convertors require that you have the codecs installed. If you don't have them, or have an old version, you might get unpredictable results.
Also, VLC is designed to be a very robust player - you can playback partially downloaded or incomplete videos with it. This means it can also often playback corrupt videos.
Encoders, on the otherhand, need every bit of data to be present and accounted for. So what VLC might play, and encoder might just throw up it's hands at. Such is the price of downloading.Read my blog here.
ANYDVDHD BD+ frames may be scrambled?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 21st Sep 2011, 20:43 -
Scrambled DVD
By thepopsicle in forum Software PlayingReplies: 3Last Post: 10th Jun 2009, 13:34 -
Scrambled DVD Playback
By shteeve in forum Software PlayingReplies: 2Last Post: 15th Dec 2008, 12:40 -
Scrambled picture from tv-out
By bizzle_613 in forum Media Center PC / MediaCentersReplies: 2Last Post: 7th Mar 2008, 08:36 -
.avi playback, video is scrambled
By dough in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2007, 13:19
