i'm having some audio sync problems with nero vision. normally if using tmpgenc i extract the movie's audio using virtualdub then select the new audio and then the movie in tmpgenc which puts the two back together again - i can seem to find out how to do this in nero vision - hence i'm getting audio sync problems.
thanks in advance!
You probably cant - nerovision is a toy.
Instead, extract the audio using virtualdubmod as an uncompressed wav file. Replace the VBR stream with the wav stream in virtualdubmod, then encode the new avi in nerovision.
I suggest virtualdubmod instead of virtualdub only because it's audio handling is simpler to use.Read my blog here.
Missing Audio after DVD authoring using Nero Vision 10
By Deerkiller in forum Authoring (DVD)Replies: 0Last Post: 11th Sep 2011, 22:18 -
No audio sound on DVDs using Nero Vision 5.3.3.0
By dweis in forum Authoring (DVD)Replies: 9Last Post: 25th Jun 2008, 19:06 -
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 16:28 -
I moderately dislike Nero Vision (audio sync)
By Matth3w in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2007, 20:53 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 13:26
