Results 1 to 18 of 18
  1. Member Rob@work's Avatar
    May 2006
    Hi everyone i'm quite new to this but wanting to ask the question, if I have a video file (avi,mpg or otherwise) how do I go about converting it to 3gp or something that my fone will be able to use? my fone supports qcif 176 x 144 if this is of any use & its a sony erricson 800i, sorry if this question has been asked before & i've overlooked the answer somewhere else but in that case if somebody could point me in the right direction i'd be very much obliged,cheers
  2. SUPER would be a good program for you, I think. If you look over to the left-hand side of your screen, you'll see the "How To" section. Look under "Convert" and you can find guides on how to use it.
    If SUPER doesn't suit you, look in the Tools section and find the drop-down menu that is labelled "Tool Features". Find the conversion you'd like (won't be hard - it's right at the top!) and search for all the tools that can do that.
    Good luck (and nice phone)!
    Cobra
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I prefer Nokia MultiMedia Converter 2 - free download if you register at their developer site - It creates the only 3gpp files my phone (SEP800) can play, and has succeeded with every source file I've tried so far.
    /Mats
    Dec 2004
    Australia
    Well 3gp is 3gp. That is the point of having open specs. If a player follows the specs and an encode follows the specs, then there are no problems. So either the other encoders/muxers you tried aren't spec compliant or Nokia is doing something funny.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    I'd say my phone doesn't play all flavors of 3gpp. I can understand that old P800 doesn't do all kinds of 3gpp, since it was among the first phones with any kind of video playback worth mentioning, but in fact, the same goes for my daughters pretty recent SE J300i - It also only plays the Nokia MM Converter 3gp files - Not anything I've managed to create with SUPER. I guess the SE player software only supports a subset of 3gp
    /Mats
  6. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Quicktime Pro can convert to 3GP.
  7. Member Rob@work's Avatar
    May 2006
    Thanks all i'll try cobras idea 1st sounds good,is it easy enough to use mate?Theres very little in the way of 3gp stuff available is there however most fones seem to use either 3gp or mp4, if it was mp4 i'd not have a problem as I could use videora ipod convertor but doesn't seem to have the right format in that program. Celtic druid maybe the resolutions different eh? could be a possibility i'm thinking since different fones use a different res screen I imagine?
  8. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Using the Nokia profile in SUPER, I created a small test 3GP movie a few weeks ago. It played fine on the PC, but the audio was out of sync on my Nokia 6102 (bleah ). Other than that, though, it seemed to work.
  9. Member Rob@work's Avatar
    May 2006
    Yeah I had noticed the GUI is a bit shadey to be honest, got no status or progress notification other than the endlessly continuous progress bar that keeps going across the screen but then its free & thats what I wanted so really we cant moan can we?did one 550Mb file on it in under 1 hour which isn't bad for this old machine so it'll probably fly on my other machine, thanks for all the replies guys & girls problem solved you've been a great help. Rob
  10. Try 3GP Converter. I use it all the time, and it looks great and doesnt seem to have Sync probs unlike all the other software Ive tried such as Nokia Multimedia Converter and SUPER and even better its free !
    It has various options to make it compatible with various phone makes.
  11. Member Rob@work's Avatar
    May 2006
    Will give it a look cheers Andy , we love free software its the way ALL software should be isn't it?
  12. Member Rob@work's Avatar
    May 2006
    3GP Convertor - how exactly does this work?i've extracted the files to a new folder & all I get when I run setup is a program that comes up in chinese I think?my advice is going to be to stick with what I know, in this case super. Although not great to look at & a few other quirky things with the interface it does exactly what it says on the tin i.e converts avi's to 3GP or 3G2 & seems to work for a number of phones too.
  13. Banned
    May 2006
    China
    SPAM
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
    Do any of these conversion programs handle 16:9 video (1.2 pixel aspect ratio)? Basically when it does the down conversion to 3G2, it needs to adjust for the 1.2 pixel aspect ratio. I tried ImToo 3GP Video Converter and it doesn't appear to handle that. The resulting video looks squeezed. Same with Super. There is an aspect ratio setting in Super, but it doesn't apper to change anything.
  15. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    SUPER will convert 16:9 as letterboxed. I have a Nokia 6280, and have found that I get the best quality (although larger files sizes) using the Nokia template, but using mpeg-4 for video and acc for audio. I can then push the resolution up to 320 x 240 - the native resolution of the phone, and the audio up to 256 @ 48khz. Great for converting music vids. I have the entire talking heads concert film Stop Making Sense at 48kHz 192 kbps ACC in under 300MB (I have a 1GB card in it)
    Read my blog here.
    Super is not doing the conversion for me. I have 16:9 selected, and it is still creating a squeezed file without letterboxing.
  17. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    What aspect ratio are you setting in SUPER ? I convert to mpeg-4 @ 320 x 240 with a 4:3 apsect ratio, and it puts the letterbox mattes in for me.
    Read my blog here.
  18. Member
    Aha! Got it. I was setting the original aspect ratio when I should have been setting the output monitor's aspect ratio (duh!).
    Now I have to figure out the ideal settings for the LG Chocolate. Although the screen in 240x320, videos of that size are too jumpy, even at low bit rate. Looks like I'm stuck at 176x144, but I have to figure out the optimal bitrate and frame seettings.
    Thanks,
    -Mike
