Can someone tell me what settings I have to set ffmpegx at so when I convert to mp4 and transfer to my PSP the video will be fullscreen without having to change the setting on the psp to zoom
also this probly would cause the picture to be distorted if the regular resolution of the video was even right?
enough to bother you though?
if so whats the closest res setting to full screen i can set it at without making the picture look warped so then I can set the psp to zoom
Currently there is no way to encode for the full 480x272 resolution of the PSP (and have it play it), Sony has locked that out - which sucks. There are several zoom options available on the PSP, just pick the one that fills the screen but doesn't stretch or chop your video.
Remember that if your source video is 4:3 you need to encode in 320x240, leaving the default of 368x208 (16:9) will stretch your video and give you your problems.
I assume that when you say wider than the PSP screen, you mean the video proportions are very letterbox at something like 2.35:1. You need to do some stuff in ffmpegx to turn it into a 16:9 video with black bars included. The subsequent video will be the same ratio as the PSP screen. There's something about it in this guide:
http://www.ffmpegx.com/psph264.html
I haven't encoded any 2.35:1 for my PSP yet, but I think that when encoding you set the ratio to 16:9 368x208, and also have the boxes "Decode with QT" and "Letterbox" checked it should turn out fine. It doesn't look like this is available as a one step solution in the PSP h.264 setting yet, only regular "PSP."
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13
