I have a external Hard drive 250G that I use for my movie files. Would it be possible to take the drive out of it's enclosure and put it in my drive bay in my computer therefore making it an internal drive? I have the extra bay already in my computer. The HD in my computer is a Maxtor 80G and the external drive is a Western Digital 250G.
Thanks, Michael
If you have an extra IDE channel to run it on, sure. Make sure you set the jumpers properly.
And this question would be better in the Computer forum. Moving you. -
If possible, try keeping it on a seperate channel from your 80GB Maxtor.
Would it make any difference that the Brand names are different on the drives?
No different. All hard drives follow the specifications lay down by Compaq known as IDE.
Unless it's a SCSI or SATA drive. The WD250G is IDE.Originally Posted by SingSing
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
what adaptor for protable hardrive should i use.
By krnjason in forum ComputerReplies: 7Last Post: 28th Nov 2008, 07:45 -
Hardrive not seen? what can i do?
By luvvbuzz in forum ComputerReplies: 12Last Post: 2nd Jul 2008, 16:48 -
Erasing Hardrive?
By ReadB4Assembly in forum ComputerReplies: 2Last Post: 14th Mar 2008, 17:34 -
Hardrive icon
By Seasonal in forum ComputerReplies: 10Last Post: 20th Aug 2007, 09:48 -
hardrive errors
By Poppa_Meth in forum ComputerReplies: 7Last Post: 7th Jun 2007, 09:58
