I recently bought a portable DVD from Zellers (like Walmart, but owned by the HBC in Canada), it is called the Hype AH-PDVD01, made in China for the HBC, but I can find no information on it, so heres what I found after a brief time playing with it. It is a "Tablet" player, with just a screen and some controls on the front (it has a remote control for all controls) and the DVD itself loads and unloads through a small slot in the top (rather like a toaster) and has speakers on the front of the unit. The screen is 7", 16X9. When I turn it on I get a yellow screen that says in black letters Hype and below that Ascent. The machine will play DVDs, burnt DVDs, burnt VCDs, burnt SVCDs, burnt MiniDVs, Mpeg ISOs, divx avis, xvid avis JPEGs and MP3s (with I believe long file name support) but NOT WMA. On the side it has plugs for Power (9 VDC), Video out (Composite) and S-Video (but both are just little mic like jacks) and a plug (mic like) for Video in (Composite). It will also play PAL and NTSC DVDs, VCDs and SVCDs. So with this description can anyone tell me what this player is, who made it, and can tell me anything more about it? All in all I like it but I would like to know if there are hacks or anything for it. Thanks.
Results 1 to 1 of 1
Lg dp351-n Portable dvd/divx player
By sfo in forum Portable VideoReplies: 2Last Post: 11th Aug 2009, 10:57 -
Proline DVDP900WX Portable Divx DVD Player
By dn2004 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Dec 2007, 17:20 -
Best Portable/Travel dvd player that is region free and can do Divx/Xvid
By expat in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Oct 2007, 12:20 -
Divx vs. Xvid performance on portable player...
By abobrien in forum Portable VideoReplies: 4Last Post: 9th Aug 2007, 08:36 -
portable dvd player with divx
By mcchex in forum DVD & Blu-ray PlayersReplies: 1Last Post: 30th May 2007, 23:25
