Hi,
I'm having trouble playing an AVI file and I'd appreciate some assistance. I'm using Windows XP SP2.
When I try to play the file, Windows Media Player gives the following error:
"Windows Media Player cannot play the file. The player might not support the file type or might not support the codec that was used to compress the file."
I've also tried opening the file with ATI File Player, RealPlayer and WinDVD and I get similar kinds of errors.
Does anyone know how I can fix the file and make it play as I'm very keen to watch it?
Thanks,
Joe
Try opening it in VirtualdubMod, it will usually tell you if there are any problems and what they are.
Help with Playing an .AVI file
By froskie in forum Software PlayingReplies: 9Last Post: 21st Sep 2010, 07:57 -
Playing avi file through firewire
By hoodleehoo in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2008, 23:05 -
Playing an avi with a separate sub file in MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 31st Dec 2007, 11:05 -
Playing PCM audio within AVI file
By acid_burn in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2007, 03:27 -
.avi file not playing all the frames
By xiaofeng in forum EditingReplies: 3Last Post: 24th May 2007, 14:51
