Hi i have an ULTRAVIEW capture card,and every time i capture a tv show i cant seem to get anything to convert the mpeg2 file to dvd so i can put it on a disc.I have cyberlink power producer,cyberlink power director and nero 7,none of them will do it, any help on the issue would great.
TMPGEnc DVD Author? GUI for DVDAuthor? DVDAuthorGUI?
Is your captured mpg DVD compliant? If not, you'll have to reencode.
/Mats -
If you are new to this hobby, you might try ConvertXToDVD. It also has an older freeware version available. It should be able to re-encode if needed and format the file for DVD burning.
For information on the DVD format, look to the upper left for 'What is' DVD. That will tell you if your file is compliant with the DVD standard. You can check the format of your file with Gspot (2.52) and compare.
If they are DVD compatible, the programs mats.hogberg mentioned should work well. For the rest, we have guides for most available software and conversions.
And welcome to our forums.
thanks for the help guys,i found the problem and i could have kicked myself for it all i had to do was put a tick in the check box that said (native mpeg) how about that lol. Although this site has basicly taught me everything i know about encodeing and dvd authering. And have only just joined the forums,you guys answerd my first post for that i am most greatfull thanks ......midnight
Good to hear. I, just like you, have also learned all i know (in this area) from VideoHelp. Again, welcome to VideoHelp!
/Mats
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
