Hello everyone,
I am having problems rendering my movie I created in Vegas 6. It begins to render to wmv format then after it reaches around 25% my entire PC shuts down. Is my hardware failing when I render? Any help will be greatly appreciate.
I am running a 1.4 AMD ghz, 1gb of ram, 2 hard drives (one for the prog and os and the other for videos), pretty decent video card.
- Mike
I would suggest overheating as a highly likely suspect. Rendering is CPU intensive, and if temperature is going to be a problem, rendering will bring it to the fore. Start by taking off the case covers and blowing out all the dust. Keep the case open, point a small electric fan intot he guts, and start your render again. If it still fails, you have other problems. If it render through, go and buy a bigger fan or some decent case fans to get circulation of air flow happening.
Read my blog here.
Google for temp monitoring utilities, install and watch temp when rendering. If going above 55-60 C check your fan/heatsink.
Vegas 8 vs Vegas 10 rendering MPG2
By schematic2 in forum EditingReplies: 0Last Post: 3rd Feb 2011, 14:32 -
Vegas Pro 9 has audio problems when rendering!
By Tahlos in forum AudioReplies: 0Last Post: 19th Jun 2010, 11:47 -
Problems with audio rendering - Sony Vegas 9 Studio
By bridgeperson in forum EditingReplies: 5Last Post: 5th Jun 2009, 09:55 -
Vegas rendering problems, clips with increased speed turns out black
By sebaa in forum EditingReplies: 0Last Post: 10th Feb 2008, 14:24 -
Dynamic RAM preview off in Vegas, could it cause rendering problems?
By Srivas in forum EditingReplies: 0Last Post: 8th Dec 2007, 03:19
