I have a number of mixed (NTSC and PAL) VCD files that I want to convert to DVD format so that I can condense them onto a single disk. The original PAL files are better quality, so I decided to keep those and convert the NTSC to PAL. I know that the DVD spec allows for MPEG1 and MPEG2 352x288(PAL) so I figured I could just reencode so that the audio was in spec, but whenever I do, DVDSP tells me that the files can not be imported because they are not in an apporpriate format. I have tried encoding as VCD and modifying audio settings, I have tried encoding as DVD-lo, I have tried demuxing and encoding, encoding then demuxing, everything I can think of and I still can not get DVDSP to accept them.
Does anyone have any idea how to get these files into a format that DVDSP will not balk at, preferrable MPEG1/2 35sx288 PAL?
Results 1 to 1 of 1
DVDSP output multiple copies?
By MikieV in forum MacReplies: 10Last Post: 8th Dec 2010, 12:10 -
DVDSP Disc only plays on MAC and not my DVD player
By jandajones in forum MacReplies: 3Last Post: 1st Oct 2010, 03:30 -
Livetype tot DVDSP help
By whiff79 in forum MacReplies: 3Last Post: 14th Mar 2010, 10:23 -
DVDSP Authored DVD - Cleaning the Code for replication?
By Adam Bolt in forum MacReplies: 2Last Post: 20th Jun 2007, 03:45 -
Motion&DVDSP-Square/Rectangular Pixels
By stretchweider in forum MacReplies: 4Last Post: 5th May 2007, 18:41
