I want to backup a movie so my mum can have it I have a multiregion DVD Player but my mum only has a region 1 can anyone tell me or help me out
Results 1 to 17 of 17
Rip with DVDFabDecrypter.
Shrink, if required, with DVDShrink. Before hitting OK, make sure you've set it to be region free. This will then go on to burn the DVD.
If it doesn't need shrinking, burn as a DVD disc with your chosen burning software.
If you get stuck, or have more questions, there are plenty of guides for both of the tools mentioned above. Have a good read.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
And if it's a PAL DVD, there's still a pretty good chance she won't be able to play it.
Or DVD Decrypter, if you can find a copy. Rip, remove all protection and region coding, voila. Then burn another copy using this modified folder.
when i hit the back up button it comes up what file it is going in but that is it i dont see where all regions are selected
You mean like this ??Originally Posted by drew23977
Look at all those pretty tabs along the top......
Hey!! what's that second one say ??
If it was a snake it woulda bit ya
And as stated, it is set to be region free by default, the real problem might be if the original is region 2 it is prob. also PAL, you live in NTSC land, will her player play PAL ?
Just changing the region code does not change it from PAL to NTSC. -
Yep!! those damn annoying region 2 ntsc dvd's from japanOriginally Posted by guns1inger
I own some also but ya know the majority of the time people have PAL region 2 disc's.
Why ya messin' with me for, i was just backing you guys up :P -
I have an Intel iMac with a Matshita UJ-846 drive. I own Region-2 DVDs that I would like to watch on my Region-1 TV-set player. I can convert the DVDs to Region-free with MacTheRipper, and then burn them with Popcorn, but will the presence of the newly burned Region-free disc in the drive use up one of the drive's five Region changes?
Sounds good. Any idea where I might look for such a firmware update?
Read my blog here.
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 15:44 -
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 11:24 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 13:42 -
Having trouble removing region code for copying
By jedbu in forum DVD RippingReplies: 5Last Post: 30th Sep 2007, 15:25
