Trying to make a backup of a dvd where unfortunately apg-warning is part of 1. vob, lasting about 7 secs. How do I remove this the easy way?
The only thing I can think of is to use vobedit on the first cellid, but can I use is to delete the first seconds, without having to resync the hole thing after?
Prefer method that doesn't include resync of sound and subs
Any guides?
Thanx in advance
Face the facts, find a solution, stick to it!
I *think* VOBBlanker can work at a cell level. DVDRemake can AFAIk also. Maybe even PGCedit (is there anything it can't do ?
If in doubt, Google it. -
Vobblanker will work fine , but only if this part has it's own unique cell id form all other's .
Vobedit can , if this part has a unique cell id , but then again you might be up for a complete rebiuld of the dvd , as thing's will have changed positioning within the title structure , and would require navigational command's to be re-checked , if to avoid any error's during playback .
Dvdshrink in re-author mode will , provided this item has a unique title by id .
Pgcedit can blank out title's , but I wouldn't consider it if the cell is the start of a title .
If this cell is a unique title , then yes .
It's a little tricky , but you can bypass the playback of this cell using the correct navigational command's ... something that would take time to explain .
If this cell has been connected to title , and has no unique cell id , then you might need to go the long way , and rebiuld the title from scratch .
Some idea's can be found in my guide's ... esspecially this one :
https://forum.videohelp.com/viewtopic.php?t=291744
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
DVD (VOB) -> MP3 (selected part only, stress-free)
By Henrik2000 in forum AudioReplies: 15Last Post: 11th Aug 2009, 13:03 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
Warning: implode()
By handyguy in forum FeedbackReplies: 1Last Post: 24th Aug 2007, 12:02
