Hello,
I'm trying to transcode a pure HDTV stream to .mp4, and the audio comes out abou 1/4 second behind the video. I'm using all defaults, I just drag the file onto the summary well, select the MP4 .mov quick preset, change the output filename, and press Encode.
I have tried this with the source filename ending in .mpg as well as .m2t (same file, just different name). EyeTV names the files ".mpg" by default. This is the one that works best, with the only problem being the audio delay described above. One thing I notice though is that it takes a long time for ffmpegX to analyze the source file when I drop it in the well.
When I rename the file to .m2t, the initial source analysis is quick, but the resultant video is horrible. It seems to be extremely processor intensive. my dual-core mac mini drops frames all over the place, and when it's not dropping frames, the video appears to be running significantly slower than the audio - perhaps even half speed.
I have searched, and haven't found any other related threads. Can anyone help?
Thanks,
Avram
Results 1 to 10 of 10
I have a somewhat related question. I have an HDTV Mpeg2 transport stream at 59 fps (720p). I'd like to convert it to h.264 at 24 fps. Is this possible? When I try with a test clip using the "h.264 x264" preset, the result is very choppy.
Using "DivX mencoder" seems to give a decent result.
Well, I am trying to do as you've asked, but it is not making any progress. It has been running for well over 2 hrs on a 3 minute clip, and it hasn't even started transcoding yet.
One thing I notice is that after selecting the preset, it has chosen 1920x1088 as the output resolution, and the status message says "Movie-Aspect is 1.78:1 - prescaling to correct movie aspect." Does this mean it is pre-processing the stream before encoding it? And even so, why would a 3 min clip take 3 hours?
Here is the current process information if it helps:
Encoding started on Mon May 8 13:10:01 EDT 2006
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
FIXME:Hardenabling SSE and SSE2 without detection
Mac OSX static build for ffmpegX
CPU: Intel (Family: 6, Stepping: 8)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
success: format: 0 data: 0x0 - 0x19e39f5c
TS file format detected.
DEMUX OPEN, AUDIO_ID: 0, VIDEO_ID: -1, SUBTITLE_ID: -2,
PROBING UP TO 2000000, PROG: 0
VIDEO MPEG2(pid=49)NO AUDIO! NO SUBS (yet)! PROGRAM N. 0
Opened TS demuxer, audio: ffffffff(pid 0), video: 10000002(pid 49)...POS=0, PROBE=2000000
VIDEO: MPEG2 1920x1080 (aspect 3) 29.970 fps 65000.0 kbps (8125.0 kbyte/s)
[V] filefmt:29 fourcc:0x10000002 size:1920x1080 fps:29.97 ftime:=0.0334
Opening video filter: [expand osd=1]
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=1920 h=1088]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 1920 x 1080 (preferred colorspace: Mpeg PES)
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
Forcing output fourcc to 58564944 [DIVX]
VDec: vo config request - 1920 x 1080 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
I also have desynchronized sound with most conversions I make.
Usually it's avi to mp4 (see attached preset), I check Decode with QT to force both audio and video conversion.
last.ffx
Problem with audio sync with an mp4/converting an mkv.
By Clowmet in forum Video ConversionReplies: 0Last Post: 21st Aug 2011, 09:58 -
problem with out of sync audio with aura4you converter(mp4 PSP)
By AaronDude in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2011, 21:10 -
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 02:03 -
Firewire HDTV Vista Audio Sync Problems
By superdud1400 in forum Video ConversionReplies: 3Last Post: 7th Nov 2008, 01:34 -
Problem with h.264 out of sync and encoding of 720p hdtv.
By vck in forum Video ConversionReplies: 4Last Post: 14th Jul 2008, 00:20
