I have had problems playing some VCD's on this player while others play fine, ive been told that to fix this i need to disable Play Back Control (PBC) the manual hints that this is possible but does not explain how to do it. Nor can I find any info on the web.
I can get round the non playing discs by re-encoding the DAT file and burning it to CDRW but this takes time.
(im using TMPGEnc to re-encode and nero to burn the VCD - just in case that helps anybody)
several websites have said that this player is a silver 343 so if someone has a PBC disable for that one it should work on my 340
to disable PBC just press "1" on your remote. this'll start playing the first chapter.
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th May 2010, 00:59 -
Disable full screen for TV when playing AVI
By slav in forum Video ConversionReplies: 2Last Post: 19th Dec 2008, 00:07 -
Pioneer 340 as replacement for Panny DMR-E80?
By LynnL in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jun 2007, 14:04 -
VLC playing problem - probably easy fix.. but I suck.
By SteveMKIIDub in forum Software PlayingReplies: 6Last Post: 22nd May 2007, 14:59
