I finally finished my latest DVD project (about 50 mins, around 2 GB), only to find a single word mistake during the final credits page![]()
Is there some program I can use to make that tiny correction without rendering the whole thing again please? In the original authoring program, MemoriesOnTV, that took close to 3 hours...
Terry, West Sussex, UK
If you want to remove it, then you can add the the video into DVDshrink twice, and use the start/stop pointer to stitch them together, without the mistake.
If you want to overwrite, then you need to make a replacement section, and try it out with VOBlanker, that has a replace function. -
Thanks both, appreciate the prompt responses. I suspect I could spend 3 hours learning those methods, so meanwhile I've started it rendering again. I'll have dinner, read a book, watch some TV...
But I expect those techniques may be easier than they sound, so I'll definitely try them at some stage. I was sort of hoping there might be some no-brainer that would let me patch up those frames rather as I would do in a still image editing program. But that was probably naive!
Tiny Problem. MKV to MP4 and edit in Vegas.
By loosecontroi in forum EditingReplies: 18Last Post: 26th Apr 2012, 15:24 -
Tiny white lines on screen during AG-1980 playback
By Bix in forum RestorationReplies: 2Last Post: 24th Apr 2009, 09:20 -
MKV, subtitles are tiny. How to change font size?
By anarchyx34 in forum Video ConversionReplies: 1Last Post: 14th Apr 2009, 01:17 -
Tiny subtitle
By projecttemp in forum Video ConversionReplies: 5Last Post: 7th Apr 2008, 06:26 -
Tiny TV Capturing Enhancement App for PC
By Soopafresh in forum DVB / IPTVReplies: 0Last Post: 12th May 2007, 17:33
