I've recoded avi with Video aspect ratio of 1.294:1 (352x272) PAL 25fps to VCD. The portion of a Avisynth script i've generated looks like this
BicubicResize(340,288)
AddBorders(6,0,6,0)
Is it correct?
Workinngs are here:
352/1.33=264 than 264*1.294=341.6 round to divisable by 4 =340 so i've arrived at height for resize script than added pillar bars for the rest. that's it.
Proof me!
Results 1 to 10 of 10
Please ask questions somewhere else, NOT in the User Guides folder!
You never did explain what you're trying to accomplish. So how would we know if you're right or not? -
No you were NOT very precise. You just said "to VCD". You never explained it's PAL, NTSC, whatever.
Actually he did ... he said pal 25fps vcd ....
try reading the post correctly (or visit your local optician) -
I am not here to debate what you think you read or not. I am pointing out that he said he had a 25 fps PAL AVI. He did not say what he wanted to convert INTO. End of discussion.Originally Posted by psx_pirate
your original resolution avi - 352x272Originally Posted by giosa
destination resolution for pal vcd - 352x288 correct?
Just from looking at this, to keep the original picture just add borders to the top and bottom:
addborders(0,8,0,8 ) without using a resizer
From looking at your oiginal script, I'm guessing you will squish the picture by adding borders to the left and right of the screen, and you will stretch the top and bottom. So your picture will have a very off AR.
If you are unsure at all how it will look, you can always open up your .avs file with a player like MPC or BS Player, and set it to 4:3.
Want to resize an avi
By janlafata in forum Video ConversionReplies: 2Last Post: 18th Aug 2009, 00:06 -
H.264 AVI to Standard DV AVI
By videovinnie in forum Video ConversionReplies: 2Last Post: 22nd Apr 2009, 11:29 -
.avi to DVD + resize
By grandsire02 in forum Video ConversionReplies: 2Last Post: 9th Mar 2009, 18:28 -
resize trouble with avi.net
By g_enqui in forum DVD RippingReplies: 2Last Post: 1st Nov 2008, 15:16 -
what is the standard size or need to resize background
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 6th Jun 2007, 14:24
