When using ffmpeg to encode an avi file to DVD, or in fact any file to DVD (I've been experimenting with the options) I notice that now when you select 2 pass encoding, the .DVD folder conatianing the VIDEO_TS & AUDO_TS folder does not get created !! Must be a bug because the .DVD folder IS created at all other times.
BTW All that gets created is the .mpg file and the .log file.
Anyone else have this problem?
Cheers,
kudos
Hmm, it's strange that the process works perfectly with every other ffmpeg switch,
there's definitely no odd characters or spaces.
I'll do some more investigating.........
Kudos
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46 -
2-pass encoding?
By andyx181x in forum DVD RippingReplies: 1Last Post: 23rd Feb 2008, 01:16 -
SVCD2DVD 2.5 One Pass vs. Two Pass encoding?
By mwkurt in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 19th Jun 2007, 15:55
