I am trying to convert the an audio file to a .wav file but I keep getting the same error message
"No audio decompressor could be found to decompress the source audio format"
(source format tag: 0055)
Can anyone help me with this problem?
I have attached a copy of the Vdub File information
Thanks[/img]
vdub%20file.doc
I installed Lame MP3 as you suggested, I am still getting the same error. I have attached a copy of the Gspot file. Do you have any more suggestions other than Goldwave?.
gspot%20file.doc -
Update your g-spot to the latest 2.52b Beta version - you will get more accurate and more detailed results.
You have managed to obscure the most important part of the g-spot screen, however the few characters that are visible look similar to another post (that I can't find at the moment) where goldwave was the solution.Read my blog here.
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 05:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 17:36 -
Vorbis decompressor for virtualdub
By mkr10001 in forum AudioReplies: 2Last Post: 14th Mar 2012, 13:58 -
[solved] virtualdub + no decompressor prob...
By j6044 in forum EditingReplies: 18Last Post: 4th Sep 2010, 08:14 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2010, 00:05
