I am having a hell of a time trying to take a DVD of my daughters Ballet performance and put it on to Premiere Pro 1.5 so I can re-edit it and then send it out to Encore 1.5, make menus and then burn it. I have tried many different programs.. Avisynth with Virt. Dub..Im too DVD Ripper...TMPGenc 3.0 express...I've tried diferent codecs..and I am able to convert it but it always look poor. The only thing that didn't look bad was no compression at all but the file was way too big. Premiere doesn't recognise VOB files so they need to be converted. Maybe I'm getting the settings wrong with these softwares.
Any thoughts?
Different codecs to try: Huffy, PicVideo, DV. I favor DV as all frames are keyframes and it makes editing easier. It is 13GB an hour, so it does take some space. You can use VirtualDub Mod to load the VOBs and the Panasonic DV codec to convert to DV. Huffy is good, though the file sizes are large, but less than raw. PicVideo is a good compromise if you are short on hard drive space.
If Premier can recognize MPEG-2, you can also use VOB2MPG to convert the VOBs to that format with no lose. The AVI conversions will all have some lose, depending on the settings.
And welcome to our forums.
Edit then convert VOB to .AVI? Best way?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2010, 16:16 -
convert .vob to .avi
By rosmari in forum Video ConversionReplies: 3Last Post: 7th Jun 2010, 21:32 -
How Do I convert mpg or avi to vob?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2009, 14:29 -
lines when I convert VOB to AVI
By odiedog in forum Video ConversionReplies: 1Last Post: 31st Jan 2009, 18:46 -
Need To Convert VOB 16:9 to 4:3 AVI or MPG
By hjordan in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 22:17
