Hello all:
I am having a very unusual sync problem while using AutoGK. I am converting some high quality files I've made down to lower resolution for use on my PDA. The source file's audio is sync'd perfectly, but the resulting file is not. Here is the weird part: The resulting file STARTS out perfectly sync'd, but gradually becomes more and more out of sync, and is a good 3 or 4 seconds off near the end. I've tried extracting the source audio as a wave and resampling, that doesn't work. I've also tried using virtualdub first to resample the source audio only and use direct stream on the video, but that did not work either. Any ideas? I've had sync issues that I've been able to resolve before, but this one has got me quite stumped.
If the sync gets worse as the video plays then the simple explanation is that either the audio or the video are different lengths. Adjust the lengths and that should fix the problem. The 'why' may be a little more complicated. Was there a framerate change or VBR audio involved?
I thought of different track lengths too, but the extracted audio is the same length as the video. Tried frame rate experiments too... changing them, keeping them same. End result is the same.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Unusual bluray format problem
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 14th May 2011, 12:50 -
Problem with fresh PC system build - unusual instability
By PartingShot in forum ComputerReplies: 24Last Post: 6th Oct 2010, 21:36 -
Unusual Raid Problem
By mysts in forum ComputerReplies: 6Last Post: 27th Apr 2008, 20:52 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 11:26
