When backing up dvd's from Paramount it's nearly impossible to get rid of the annoying blue startup-screens, and still preserve the menues and extra's.
Is there a guide on this or can anyone help with this?
Would it be possible to let "play first" point to main menu, and would that do the trick?
Thanx in advance (for this good forum as well)
ClaudiuS
Results 1 to 14 of 14
Face the facts, find a solution, stick to it!
VobBlanker
You can get rid of the warning screens, previews, anything you want so it will jump right to the main menu. -
Like waving a wand isn't it? Well nothing happened! Anyone who can help?
Face the facts, find a solution, stick to it! -
i suggest VobBlanker
https://www.videohelp.com/guides.php?guideid=869#869"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hello hello hello hello........Originally Posted by BJ_M
I could've swore i just heard an echo...
OK, I didn't see the wand had a button. That helped, thanx for the advice and the link.
Well, VobBlanker won't jump right to the menu after you blank out the garbage. It will still pass by all that blanked stuff, although the delay is usually pretty short, but not always. On my standalone, I've seen delays of up to about 5-6 seconds or so when all the stuff was blanked with one of the Disney DVDs with all the forced previews, before hitting the menu.
Yes, and the best way to accomplish that is with PGCEdit:
https://www.videohelp.com/~r0lZ/pgcedit/third_party/blutach/How_to_use_PgcEdit_new_macro.htm
However, instead of Macros – Jump to PGC Upon DVD Insert as it was when the guide was written, it's now PGC – Jump to PGC Upon DVD Insert. And after doing that, if it's a DVD9 you're shrinking down, be sure to go to VobBlanker and blank all the crap out. If it's a DVD5, it's sufficient to just do the Jump to PGC Upon DVD Insert. -
Love your clear answers manono. ;o)
Problem with the above solution, which I've used several times, is that, at least I think so, that you miss some commands in the flowchart. Postcommands or what ever. SO it's not always a usable method.
ThanxFace the facts, find a solution, stick to it! -
There's certainly nothing wrong with doing it entirely with VobBlanker, and it's easy enough. I just find the PGCEdit solution, combined with VobBlanker afterwards, a bit more elegant. I can't say that I've ever had a problem doing it with PGCEdit, though. If you run into the problem with the resume flag, as described in the guide, following the instructions has fixed the problem the couple of times I've seen it.
Maybe you're not right-clicking on the menu where you want to start and "Toggle PGC Pre/post Breakpoint" before running the Trace and then doing the "Jump To PGC Upon DVD Insert" after making your way back to there. -
Sorry, I'm not speaking clearly. The problems described is experienced when blanking with vobblanker.
I use IFOEdit to remove unwanted trailers, FBI Warnings etc using the delete playback option. Doing it this way avoids the "LAG" sometimes experianced on standalone players when using VobBlanker. Also a point to note is that IFOEdit is FREE and is underated. It has its own preview function so you can make sure what you are deleting from playing back is what you want to delete. I can send you a quick guide on how to perform this - Once you have done it once or twice its childplay and not as daunting as I believed it to be on my first attempt. Anyway its your decision at the end of the day - Just throwing in another contender into the ring.
Or maybe I'm not understanding clearly. Boy, did I get that one wrong.
Based on what Neil1970Poole said, maybe the PGCEdit method isn't the best way, but just one way.
I guess no way is THE right way. Protection schemes and nag screens are nearly all different, allthough there are similarities. One way may be best for some purpose, another better for others.
The best way, I think will allways be to understand what you actually want to do, and then use the tool best suited to do that.Face the facts, find a solution, stick to it! -
Didn't get this pgcedit way to work properly, but found another very easy way myself.
When opened in DVDRemake you can see that play first points to VTS_1 (root menu), and from there it starts these blue screens.
I found the (right) root menu, the one with options to choose setting, extras or play, right-clicked in panel and picked the option to make it the "root menu".
Voila, job done!Face the facts, find a solution, stick to it!
Paramount Returns Yanked Blu-ray Titles To Stores
By cracula in forum Latest Video NewsReplies: 7Last Post: 4th May 2008, 22:07 -
One more nail...it looks like Paramount is going Blu Exclusive too
By tzm in forum Latest Video NewsReplies: 26Last Post: 9th Jan 2008, 06:29 -
Paramount to Drop Blu-Ray High-Def DVDs
By akrako1 in forum Latest Video NewsReplies: 71Last Post: 29th Aug 2007, 19:40
