For some reason my nero 6 started burning dvds at 4x speed.
The speed change window cannot be changed. I tried different dvds, no change.
And it happened for no reason.
I am curious, why is that?
I mean before I could choose my recording speed no problem.
I use Asus DRW-1604P.
Have you changed/updated Nero or your drive recently?
If all else fails. Uninstall Nero, remove the drive from device manager, reboot. The OS should find and install the drive. Then reinstall Nero.Google is your Friend
ffmpegX DVD Burning - Weird Runtime After Conversion??
By tictacjak in forum Authoring (DVD)Replies: 0Last Post: 7th Sep 2011, 12:31 -
How to limit dvd burning speed
By zakman in forum Authoring (DVD)Replies: 6Last Post: 19th Sep 2009, 01:53 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 03:41 -
The best burning speed for the most compatibility with DVD players?
By gom in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:30 -
dvd burning speed
By nobbyiscool in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2007, 08:54
