Just installed Dazzle's video creator 2 card and after startup my computer cannot see my dvd rom or my cdrw drive
has any one had this problem and can help me
technical support is not mutch help.My cpu is a AMD athlon k7 512 ram i have tried it in all pci slots.Thanks
Does the DVCII work in your system? If not, it sounds like the problem I've read where the DVCII doesn't work with some AMD based motherboards. I myself have an AMD and a DVCII and don't have any problems, but I think my motherboard is one that is ok. -
my motherboard is a sis 735 ddr chipset technical support didnt think it was the motherboard most times it takes about 1 hr to get thim on the phone.I was told to try diableing DMA in the bios but do not know how or the steps to doing that.
Are you using WindowsXP? XP has a pretty common "disappearing CD drive" issue. Logical drives seem to disappear on some systems, requiring a reboot. And it does not recognize burners as burners sometimes. See the http://www.ntcompatible.com boards for a good thread on this. Basically the fix is to install the CDRW patch, remove the patch, then reinstall the patch. It fixed my problems.
This may or may not be your problem (related to the DVC2).
Sabrent Video DVD Maker Video Capture Creator Anyone?
By Rayj00 in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2011, 11:10 -
Dazzle Video Creator Plus Help Please!
By FragpooL in forum Capturing and VCRReplies: 1Last Post: 24th Jun 2011, 00:51 -
Video to Dazzle and Tv
By fellixombc in forum Capturing and VCRReplies: 1Last Post: 6th Jul 2010, 16:52 -
Dazzle Vid Creator Plus, or TV tuner card?
By cwb in forum Capturing and VCRReplies: 3Last Post: 21st Jul 2009, 09:38 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08
