I was wondering what the best way to create a disc of episodes would be.
I am wanting to take a 70 episode series and put it on 2-3 dvd's.
Can you set up a vcd and burn it on to a dvd?
Quality isn't a huge deal so what would be the best option.
I prefer to use nero.
Yes you can set vcd as dvd.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
1. I'd recommend you don't use Nero for the encoding side of things.
2. http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm and https://www.videohelp.com/calc.htm - your friends here, big time.
3. Single Layer DVDRs, or Dual Layer ?
4. Running time (approx) of each episode ?If in doubt, Google it. -
Using a bitrate calculator, audio set at 160 kbps gives a video bitrate of 925 kbps. Using VCD resolution and 2-pass VBR it should be watchable.
"Art is making something out of nothing and selling it." - Frank Zappa -
I'd recommend using 4 DVDs. That would result in 420-minutes (or 7-hours) per DVD and allow you to encode at VCD quality bit rates (video at 1150 kbps & audio at 224 kpbs) and leave you with a margin of 240-MB per DVD.
Reasonably priced media Player for the noobie..?
By scharfg in forum Media Center PC / MediaCentersReplies: 4Last Post: 5th Jan 2010, 14:38 -
noobie with AutoGK questions.
By celchlepp in forum DVD RippingReplies: 9Last Post: 17th Sep 2009, 20:38 -
Wi-Fi noobie confusion.
By Xylob the Destroyer in forum ComputerReplies: 18Last Post: 23rd May 2008, 11:59 -
Xbox 360 help. (NOOBIE)
By Neoistheone2000 in forum Video ConversionReplies: 8Last Post: 2nd May 2008, 21:27 -
Noobie here
By Explorateur in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2008, 15:59
