Tried converting RMVB file to DVD with mpeg2enc. Takes very long, at the end I get a "failed" message, but a VIDEO_TS folder is produced. Burned this to DVD. The video is fine, but the audio is unacceptable.
Here's part of the log:
Encoding started on Tue May 2 18:58:26 PDT 2006
/Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff/
/Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff/: File exists
-f 5 -b 4000 -q 3 -B 260 -V 230 -a 2
-F 1
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
MPlayer dev-CVS-060413-06:15-3.3 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
get_path('codecs.conf') -> '/Users/xxx/.mplayer/codecs.conf'
Reading /Users/xxx/.mplayer/codecs.conf: Can't open '/Users/xxx/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: Can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Using built-in default codecs.conf.
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm:waveheader' '-v' '-osdlevel' '0' '/Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb' '-aid' '0'
get_path('font/font.desc') -> '/Users/xxx/.mplayer/font/font.desc'
font: can't open file: /Users/xxx/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using Darwin accurate timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/xxx/.mplayer/input.conf'
Can't open input config file /Users/xxx/.mplayer/input.conf: No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf: No such file or directory
Falling back on default (hardcoded) input config
get_path('DesperateHousewivesSeason2Ep20.rmvb.conf ') -> '/Users/xxx/.mplayer/DesperateHousewivesSeason2Ep20.rmvb.conf'
Playing /Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.
get_path('sub/') -> '/Users/xxx/.mplayer/sub/'
[file] File size is 192704864 bytes
STREAM: [file] /Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
Checking for YUV4MPEG2
ASF_check: not ASF guid!
Checking for NuppelVideo
FAAD: compressed input bitrate missing, assuming 128kbit/s!
Checking for REAL
REAL file format detected.
real: Header size: 18
real: Header object version: 1
real: File version: 0
Chunk: PORP (504f5250) (size: 0x32, offset: 0x12)
First index chunk offset: 0xb77ad9c
First data chunk offset: 0x42b
Flags (9): [save allowed]
Chunk: TNOC (544e4f43) (size: 0x73, offset: 0x44)
Chunk: RPDM (5250444d) (size: 0x9f, offset: 0xb7)
Found new stream (id: 0)
Stream description: Audio Stream
Stream mimetype: audio/x-pn-realaudio
==> Found audio stream: 0
Found audio stream!
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): image not found
ion: 5
header size: 65
coded_frame_size: 278
sub_packet_h: 1
frame_size: 278
sub_packet_size: 278
samplerate: 44100, channels: 2
audio fourcc: A4PM (4134504d)
======= WAVE Format =======
Format Tag: 20557 (0x504D)
Channels: 2
Samplerate: 44100
avg byte/sec: 12000
Block align: 278
bits/sample: 16
cbSize: 0
### skipping 0 bytes of codec info
Chunk: RPDM (5250444d) (size: 0x70, offset: 0x156)
Found new stream (id: 1)
Stream description: Video Stream
ERROR: Could not open required DirectShow codec drvc.so.
Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
ERROR: Could not open required DirectShow codec drv4.so.6.0.
ERROR: Could not open required DirectShow codec drv43260.dll.
lvideo
==> Found video stream: 1
video fourcc: 04VR (30345652)
H.263 ID: 40008000
unknown id: 40008000
Chunk: RPDM (5250444d) (size: 0x25b, offset: 0x1c6)
Found new stream (id: 2)
Stream mimetype: logical-fileinfo
Got a logical-fileinfo chunk
### skipping 541 bytes of codec info
Chunk: ATAD (41544144) (size: 0xb77a97b, offset: 0x421)
Packets in file: 202014
Reading index table from index chunk (192392604)
entries: 21723
stream_id: 0
next_header_pos: 192696746
Reading index table from index chunk (192696746)
entries: 577
stream_id: 1
next_header_pos: 192704844
Reading index table from index chunk (192704844)
entries: 0
stream_id: 2
next_header_pos: 0
Auto-selected RM video ID = 1
VIDEO: 04VR [40008000,01081020] 608x328 (aspect 0.00) 23.00 fps
AUDIO: A4PM [4134504D]
VIDEO: [RV40] 608x328 24bpp 23.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:11 fourcc:0x30345652 size:608x328 fps:23.00 ftime:=0.0435
Clip info:
author: “¡µÈ‘?S-Files_»¸Ãÿ ÷??˜
copyright: www.ydy.com(C).2006
get_path('default.sub') -> '/Users/xxx/.mplayer/default.sub'
Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding)
dec_audio: Allocating 4608 bytes for input buffer.
dec_audio: Allocating 49152 + 65536 = 114688 bytes for output buffer.
FAAD: Decoder init done (0Bytes)!
FAAD: Negotiated samplerate: 44100Hz channels: 2
AUDIO: 44100 Hz, 2 ch, s16be, 128.0 kbit/9.07% (ratio: 16000->176400)
Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio) decoder)
Using (default) progressive frame mode.============================================= =============================
Opening video decoder: [realvid] RealVideo decoder
realvideo codec id: 0x40008000 sub-id: 0x01081020
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.so'
Read the RealVideo section of the DOCS!
VDecoder init failed
opening shared obj '/Library/Application Support/ffmpegX/reallib/drv4.so.6.0'
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
INFO: RealVideo codec init OK!
Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
Building audio filter chain for 44100Hz/2ch/s16be -> 0Hz/0ch/s8...
[libaf] Adding filter dummy
[dummy] Was reinitialized: 44100Hz/2ch/s16be
[AO PCM] File: audiodump.wav (WAVE)
PCM: Samplerate: 44100Hz Channels: Stereo Format s16le
[AO PCM] Info: Faster dumping is achieved with -vc null -vo null
[AO PCM] Info: To write WAVE files use -ao pcm:waveheader (default).
AO: [pcm] 44100Hz 2ch s16le (2 bytes per sample)
AO: Description: RAW PCM/WAVE file writer audio output
AO: Author: Atmosfear
INFO: [yuvscaler] SVCD output format requested in NTSC norm
be -> 44100Hz/2ch/s16le...
[libaf] Adding filter format
[format] Changing sample format from big-endian 16-bit signed int to little-endian 16-bit signed int
[format] Accelerated endianess conversion only
Starting playback...
INFO: [yuvscaler] input: frame size: 608x328 pixels (299136 bytes)
INFO: [yuvscaler] input: frame rate: 23/1 fps (~23.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?
INFO: [yuvscaler] from 608x328, take 608x328+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x360, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
old len = 0, new len = 65540
VDec: vo config request - 608 x 328 (preferred colorspace: Planar I420)
Trying filter chain: vo
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
Trying filter chain: scale vo
VDec: using Planar I420 as output csp (no 0)
Movie-Aspect is 1.85:1 - prescaling to correct movie aspect.
VO Config (608x328->608x328,flags=0,'MPlayer',0x30323449)
line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] black lines: 60 above and 60 under
INFO: [yuvscaler] black columns: 0 left and 0 right
INFO: [yuvscaler] frame rate: 23.000 fps
INFO: [yuvscaler] Scaling ratio for width is 38 to 45
INFO: [yuvscaler] and is 41 to 45 for height
al converter
REQ: flags=0x407 req=0x0
VO: [yuv4mpeg] 608x328 => 608x328 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools
VO: Author: Robert Kesterson <robertk@robertk.com>
INFO: [mpeg2enc] Selecting Stretched SVCD output profile
INFO: [mpeg2enc] Progressive input - selecting progressive encoding.
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpv
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
*** [scale] Allocating mp_image_t, 608x328x12bpp YUV planar, 299136 bytes
me: no
INFO: [mpeg2enc] Using one-pass rate control
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] PAR = 0
INFO: [mpeg2enc] NEW GOP INIT length 15
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
*** [vo] Allocating mp_image_t, 608x328x12bpp YUV planar, 299136 bytes
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?
INFO: [mpeg2enc] Enc1 0 0( 0) I q=3.00 [100% Intra]
INFO: [mpeg2enc] Enc1 1 1( 1) P q=3.00 [0% Intra]
INFO: [mpeg2enc] Enc1 2 2( 2) P q=7.04 [75% Intra]
INFO: [mpeg2enc] Enc1 3 3( 3) P q=5.64 [0% Intra]
INFO: [mpeg2enc] Enc1 4 4( 4) P q=3.44 [1% Intra]
INFO: [mpeg2enc] Enc1 5 5( 5) P q=3.00 [1% Intra]
INFO: [mpeg2enc] Enc1 6 6( 6) P q=3.00 [1% Intra]
INFO: [mpeg2enc] Enc1 7 7( 7) P q=3.00 [5% Intra]
INFO: [mpeg2enc] Enc1 8 8( 8) P q=3.00 [8% Intra]
INFO: [mpeg2enc] Enc1 9 9( 9) P q=4.09 [12% Intra]
INFO: [mpeg2enc] Enc1 10 10(10) P q=5.52 [16% Intra]
INFO: [mpeg2enc] Enc1 11 11(11) P q=6.53 [18% Intra]
INFO: [mpeg2enc] Enc1 12 12(12) P q=6.19 [20% Intra]
INFO: [mpeg2enc] Enc1 13 13(13) P q=5.77 [16% Intra]
INFO: [mpeg2enc] Enc1 14 14(14) P q=4.49 [0% Intra]
[many like these]
demux_real: Found INDX chunk. EOF.
ds_fill_buffer: EOF reached (stream: video)
INFO: [mpeg2enc] Enc1 58607 58607( 5) P q=3.00 [7% Intra]
EOF code: 1
Uninit audio filters...
[libaf] Removing filter dummy
[libaf] Removing filter format
uninit audio: faad
FAAD: Closing decoder!
uninit video: realvid
INFO: [mpeg2enc] Enc1 58608 58608( 6) P q=3.00 [6% Intra]
Exiting... (End of file)
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 58611!
INFO: [mpeg2enc] Enc1 58609 58609( 7) P q=3.00 [7% Intra]
INFO: [mpeg2enc] Signaling last frame = 58610
INFO: [mpeg2enc] Enc1 58610 58610( 8) P q=3.00 [0% Intra]
INFO: [mpeg2enc] Sequence end inserted
INFO: [mpeg2enc] Guesstimated final muxed size = 990338741
wait, encoding to mp2 audio with mp2enc...
INFO: Opened WAV file, freq = 44100 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 446300160 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpa"
INFO: [mplex] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
INFO: [mplex] File /Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpv looks like an MPEG Video stream.
INFO: [mplex] File /Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 23.976 frames/sec
INFO: [mplex] Bit rate : 4000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 4317296
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in delay = 7507 Video delay = 7507 Audio delay = 11261
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 0 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 0 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 58610
INFO: [mplex] STREAM e0 completed @ frame 58610.
INFO: [mplex] STREAM c0 completed @ frame 105417.
INFO: [mplex] Multiplex completion at SCR=227701467.
INFO: [mplex] Video e0: buf= 0 frame=105410 sector=00451814
INFO: [mplex] Audio c0: buf= 3360 frame=105417 sector=00035070
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 910890310 bytes
INFO: [mplex] Sequence headers: 3976
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 58611
INFO: [mplex] No. Groups : 3976
INFO: [mplex] No. I Frames : 3976 avg. size 36236 bytes
INFO: [mplex] No. P Frames : 54635 avg. size 14035 bytes
INFO: [mplex] No. B Frames : 0 avg. size 0 bytes
INFO: [mplex] Average bit-rate : 2980800 bits/sec
INFO: [mplex] Peak bit-rate : 4328800 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 149375
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 70840896 bytes.
INFO: [mplex] Syncwords : 105418
INFO: [mplex] Frames : 105418 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
DVDAuthor::dvdauthor, version 0.6.11.
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpg...
WARN: not a valid DVD frame rate: 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
STAT: VOBU 16 at 4MB, 1 PGCS
STAT: VOBU 32 at 7MB, 1 PGCS
STAT: VOBU 48 at 11MB, 1 PGCS
STAT: VOBU 64 at 15MB, 1 PGCS
STAT: VOBU 80 at 19MB, 1 PGCS
[many like these]
WARN: Video PTS does not line up on a multiple of a field.
INFO: Video pts = 0.125 .. 1222.533
INFO: Audio[8] pts = 0.125 .. 2530.157
STAT: VOBU 3976 at 958MB, 1 PGCS
INFO: Generating VTS with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
STAT: fixing VOBU at 4MB (17/3976, 0%)
STAT: fixing VOBU at 7MB (33/3976, 0%)
STAT: fixing VOBU at 11MB (49/3976, 1%)
STAT: fixing VOBU at 15MB (65/3976, 1%)
STAT: fixing VOBU at 19MB (81/3976, 2%)
STAT: fixing VOBU at 24MB (97/3976, 2%)
STAT: fixing VOBU at 29MB (113/3976, 2%)
WARN: audio sector out of range: -8270 (vobu #115, pts 35.306)
WARN: audio sector out of range: -8364 (vobu #116, pts 35.618)
WARN: audio sector out of range: -8447 (vobu #117, pts 35.931)
WARN: audio sector out of range: -8538 (vobu #118, pts 36.244)
WARN: audio sector out of range: -8648 (vobu #119, pts 36.557)
[many like these]
STAT: fixed 3976 VOBUS
INFO: dvdauthor creating table of contents
INFO: Scanning /Users/xxx/Documents/Download/DesperateHousewivesSeason2Ep20.rmvb.ff.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
Tue May 2 21:44:04 PDT 2006
You should have a .mpg file created somewhere. Try playing it with VLC. Does it look/sound fine?
OK, now I figured out the problem. When playing the VIDEO_TS folder using Apple DVD Player, the audio is fine, but the video is choppy: It freezes for a short moment every second or so. So, I think the DVD player does the same, it slows down with the video and makes the sound choppy, and that made me think that something was wrong with the audio. The strange thing is that VLC plays the VIDEO_TS just fine. However, I need to be able to burn to DVD and make a disc that plays in my DVD player. Any ideas?
Conversion Question: rmvb file via dvd player
By seifhatem in forum Newbie / General discussionsReplies: 5Last Post: 17th Nov 2010, 12:01 -
No sound upon conversion from RMVB to DVD using WinAVI Video Converter
By kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 17:28 -
RMVB conversion end up without audio
By alc112 in forum Video ConversionReplies: 22Last Post: 14th Jan 2010, 01:34 -
choppy audio from mpg to DVD conversion - Help
By Warhammerx in forum Video ConversionReplies: 4Last Post: 7th Dec 2008, 19:25 -
sound choppy on rmvb file in my DVD disc.
By csh in forum Software PlayingReplies: 4Last Post: 31st Oct 2008, 22:13
