Results 1 to 15 of 15
  1. Trying to backup "Aeonflux" using "AnyDVD" and "Shrink". "AnyDVD" completes fine without errors and "Shrink" completes but I get an error when "Nero" goes to burn. Help. Thanks.
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Use dvdfab
    What We Do In Life, Echoes In Eternity....
    Feb 2003
    I used anyDVD 5.9.5.8, DvdShrink 3.2.0.15 in movie-only mode, and burned with Nero 6.3.1.6 on Win XP x64 with no errors.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    I ripped it with plain ol' DVD Decrypter, shrank it with DVD Shrink to an ISO then burned it back with DVD Decrypter.
  5. It is possible that there is unreferenced material in the files which causes Nero to cough when trying to burn. I would suggest using vobblanker to get rid of the unreferenced material then burn using Nero.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  6. Nero 6.6.1.4 wouldn't burn it. DVD Decrypter would. Thanks.
    Same.
  8. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sounds like a software issue and not a movie issue.
    Google is your Friend
  9. Banned
    Feb 2005
    USA
    I used DVD Fab Decrypter and Nero 7 to burn. No shrinkage involved or would I want to.
    Oct 2005
    AnyDVD and shrink are both ripping tools. They will crash. Just use an updated AnyDVD w/DVD program (Clone DVD), or use updated DVDFab Decryptor and then shrink it as stated earlier.
    Aug 2002
    I amde a copy of aeon witht he new nero 7 and new anydvd with no problems.And when i say new i mean the new ver of the software.
    Scoot
    ScootZilla
  12. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Scoot
    Thanks for clarifying. I thought you meant the old new version.
    Oct 2005
    Canada
    used DVD Shrink 3.2 and nero 6 without any problems.
    Dec 2006
    I main-movied this one with easyDVDclone and had no problems. My magnavox player wouldn't play it properly (a lot of skipping towards the last twenty minutes) but worked great in the computer and on my RCA player.
    I didn't bother with the bonus features.
  15. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The skipping is most likely a media issue. Either you are using cheap media or you are using a brand/type that the player doesn't like.
