Hello, I have a VCR which I want to connect to my pc so I can convert all my VHS tapes into avi/mpeg format. I do not mind if the quality isnt the best, and I do not want to spen too much cash.
Which of the following TV cards would you guys recommend?
1. Leadtek® TV2000XP PCI TV Tuner + REMOTE ( NO FM), support video capturing - Certified by Microsoft XP WHQL Test
2. Leadtek® TV2000XP Expert PCI TV Tuner + FM + Remote Control, 10-bit Video Recorder - WW Broadcast Audio(Nicam;A2)
3. Pinnacle Systems™ - Studio PCTV 40i - TV Tuner (PAL I), RCA/S-Video Input (No Output)
4. Pinnacle Systems™ - Studio PCTV 50i - TV Tuner (PAL I), RCA/S-Video Input (No Output) , Includes Remote Control
Many thanks for your assistance![]()
This one can do the job, and it is not expensive:
http://www.geeks.com/details.asp?invtid=SBT-TV&cpc=SCH&srm=0No tengo miedo a la muerte. Solo significa sońar en silencio. Un sueńo que perdura por siempre. .. -
unfortunately I am in South Africa, and it doesnt look like anyone here stocks these..are the above cards not suitable?
can anyone help me here?
Will any of the following cards allow me to record VHS through my PC?
If you could please help me I would be grateful.
Thanks, -
VHS captures are the toughest to handle - I'd say these cards are relatively equal, but no matter which you go for, you'll need a TBC (time base corrector).
Frankly, a DVD recorder (many have a TBC built in) may be your best option. But then you have the aditional work of ripping the recorded DVD if you want to do some edits and stuff.
/Mats -
thanks, damn. I thought it was going to be straightforward.
Plug VCR into the card's IN connector. Play the VHS and screen capture whats shown on the PC screen.... -
No, that's not the way it works.
3 & 4 seems to be the same basic card - The 50i comes with a remote - that's the difference.
The diff between 1 and 2 seems to be the Expert support for WMV/WMA. From what I can read, I'd go for the one of the Leadtek cards. But OTOH, your shouldn't believe marketing bull sh*t - try to find some reviews on the web.
/Mats
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 8th Oct 2011, 00:01 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 16:51 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
