Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I HAVE 4 VIDEOS THAT are .ts fiels how do i put them on a dvd they are 4.22G each
    also i have a ts file that is 20G what can i do with that file
    all are 1080i files woth 5.1
    hdtv2dvd but you will lose the 1080i size, it will downconverted to dvd resolution.
    if you want to keep them as ts you can split it with hdtv2mpeg2 and just burn as data on a dvd, but they wont work dvd players.
  3. Member rvelez's Avatar
    Oct 2005
    How did you make these files?
  4. dl them at hdbits . org
