Hi hopefully a simple question for you.
I have recently tried two recorders ...
Technika DVR-2005
Chili DVR-8500x
These are obviously cheaper brands but I have a question about recording.
Are all DVD recorders noisy when recording??
These models obviously have a pc dvd-writer inside cos they make the same fanlike noise when recording as a pc one does.
Are all recorders like this or do only the cheap models have pc dvd-writers inside??
By the way for the price these are good machines
Inside these DVRs, are chip sets from a few companies. One of this chip sets can be very hot, when the chip is capturing and encoding. Thus the DVR makers put in a small fan to keep it alive.
Most japanese venders use their own chip sets, and cost 20% or more. But you have more choices. -
DVD recorders appear to be getting quieter - but aren't as silent as a VCR. The Panasonic E-20 that I have had noticeable fan noise when new....and still does. It doesn't affect the operation, though.
Panasonic E-55 is much quieter, smaller, etc.; but doesn't have the heft and solid build of the old E-20.
Maybe some day they won't need fans. -
The fan noise came from the fan used to deal with the heat. The heat is generated by intense computation. Just like P4 overheat when you run a high utilisation % application.
Real-time capture and ecnoding need a lots of CPU/Hardware horse power. Remember P3 and Old P4 can't even capture mpeg2 without dropping frame ? -
But my question was....
Do all DVD recorders have noisy fans? or just the cheaper ones -
Look at the back of the DVRs, if there is a fan, then you most likely going to hear it go off, during recording.
If you want to aviod this, then pick the lower end model of JVC, Pioneer, or Toshiba.
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
Audio Noise on Vado when recording in car
By raticosa in forum Portable VideoReplies: 1Last Post: 10th Sep 2011, 19:34 -
Clicking noise when recording with external mic on Canon VIXIA HF 11
By NewChannelMedia in forum AudioReplies: 8Last Post: 4th Feb 2010, 15:50 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Recording a better copy of an old recording.
By cyber-junkie in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 16:48
