Hi, does anyone know how to adjust the pixel aspect ratio for virtualdub exports? I've looked in the default filters and cannot see anything which can do this, only the physical dimensions of the frame.
You can change the display aspect ratio after converting with virtualdub with something like mpeg4modifier if you are making an avi with divx,xvid...but many software players ignores display aspect ratio in avi files.
If you are going to convert to dvd later change the aspect ratio when you are converting to dvd instead. -
The final output is a DV avi which is why I want to alter the pixel aspect within virtualdub. Can this be done?
No. But I think you can change to 16:9 with DV Date Time Changer, http://www.video2dv.com/index.php?lang=en&page=dvdtc after you converted to dv avi.
Hey people... i know this is an old thread but i got the same issue.. i need to export in dv with subtitles hardsubbed and this pixel aspect ratio mess with the result ( the subtitles get all squeeze in the final DVAVI file in 16:9 )
it's there an update on this subject? -
BTW, better to START a new thread than dredge up such an old one...
One way - load DV into Vdub, resize the video to a 16:9 DAR with 1:1 PAR (say, 853x480), apply subtitles, resize BACK to 720x480, export to DV using Cedocida DV codec w/ DAR setting of 16:9. Yes, your subtitles will TEMPORARILY look squished. However, they will play fine & correctly (with a good player). Yes, they will have to use FULL Re-encode instead of Direct stream copy, but you'd have to do that anyway if you applied subs...
Scott -
Square pixels or 16:9 Pixel aspect ratio?
By Scherwin in forum Video ConversionReplies: 6Last Post: 18th May 2010, 13:47 -
pixel aspect ratio?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Aug 2009, 14:53 -
Which encoder keeps Pixel Aspect Ratio intact?
By hadiceberg in forum DVD RippingReplies: 11Last Post: 8th Jun 2009, 08:09 -
pixel aspect ratio in stills for dvd
By SexMoron in forum Authoring (DVD)Replies: 7Last Post: 4th Jan 2008, 09:11 -
Aspect Ratio: Pixel AR and Display AR
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 18:42
