That is just plain CRAP! I bought the DVDs, I paid good money for them, and I have the right to protect my investment - I have the right to create backups of the DVD files to view or archive so that the original DVD disks will be less likely to become damaged with repeated use. And anyone who doesn't believe in this right needs to move to a country like China or Cuba, where rights are considered to be privileges, to be given or taken away at the whim of the ruling dictators and their 'enforcement' agencies!Originally Posted by lisahuahua
Results 31 to 43 of 43
Decrypting a DVD breaches the DMCA in the US and I am not sure that there is any definitive fair use bypass. Definatly there should be though.
Anyone who doesn't believe in that right, they probably work for the MPAA or similar or at least accept bribes from them. -
Those settings of the Divx codec effect the motion search precision. The effect on quality is very small once you get above the lowest quality settings. Anything above "Balanced" is usually a waste of time. If you work in constant quality mode (single pass, target quantizer) it's easy to see what effect the different motion search precisions have -- the output is always the same quality, but the more motion search precision you use the smaller the file will be. You'll see that Insane rarely gets you more than a 1 percent smaller file than Balance -- but it will take 4 times longer to encode.Originally Posted by mjanspacher
Well of course all calculators give about the same bitrate -- the relationship between bitrate and file size is simple: size = bitrate * running time. The reason you were getting slightly different values was because of varying audio bitrates and maybe a little padding that some calculators use (it's a pain if your file comes out a few bytes to big to fit on a CD, if that's your goal). But note, there's no way of predicting exactly what quality any particular bitrate is going to give you. Different video characteristics will require different bitrates to get the same quality.Originally Posted by mjanspacher
I usually don't care about the exact file size so I use Constant Quality encoding. I pick the quality level I'm happy with and encode in a single pass. The file comes out to whatever size is necessary to get that quality. -
Just because the greedy lawyers have been successful in convincing a bunch of corrupt judges and law-enforcement personnel that this is 'the law' does NOT make it either lawful or ethical. The citizens of this country are still supposed to be in charge of their own destinies...and their own government!Originally Posted by celtic_druid
Jagabo - thanks a bunch for this info. It is very helpful to us 'newbies'! Helps us to understand what's going on, and why.
mjanspacher, You are using 2-pass (or more) variable bitrate right? When going for small file sizes VBR will get you much better results than single pass constant bitrate.
Another thing to keep in mind: when you see decent quality DVD-to-Divx files from the web they rarely have a full 640x480 frame size. The larger the frame the higher the bitrate you will need to maintain image quality. Of course, you are trading off overall resolution to get fewer macroblocks.
Also be sure you disable the "honor 'repeat first field' flag" option in VirtualDubMPEG2 if your DVD is 23.976 fps progressive. This will prevent VirtualDubMPEG2 from creating 29.97 fps interlaced frames from the 23.976 fps progressive source. Fewer fps means you can use a lower bitrate (and you won't have to deinterlace or inverse telecine). The option appears when you check the "Ask for extended options after this dialog" option on the File Open dialog. -
Currently I am using the avi.NET software with fairly good results. I have increased my target file size to 450Mb, and the improvement in quality is quite noticeable. The only issue I am still experiencing is an occasional 'hiccup' in the audio of the finished AVI file - changing the target size has not effected this at all, as far as I can tell. It is a minor irritation, but since I have the original DVDs, it's no big deal - the biggest problem I have with this is figuring out what is causing it and how to resolve it.
As far as I can tell, avi.NET first extracts the AC-3 audio track(s) to a WAV file, then converts the WAV to an MP3 (which I assume is layered back into the finished AVI at some point). Maybe these 'hiccups' are caused by the program attempting to fine-tune the synchronization of the audio file and the video file? The video conversion is using two-pass, but that's all I can tell from the program (the rest is all brain surgery, as far as I'm concerned). I think it may be time to invest in a 'Video File Conversion Techniques for Dummies' book.
Jagabo, again your input is greatly appreciated. The point you make about the frame size is something I had not considered, but certainly makes sense. I have been attempting all of my conversions at full size, which will result in a larger overall file size in the finished product. -
But since XviD is older and there are constantly new updates to DivX, would DivX have the same or better quality and compression by now?Originally Posted by jagabo
I don't think Divx is spending much time improving the encoding quality. They seem to be concentrating on things like menus, chapters, and subtitles.Originally Posted by abazabam
Too late. DXN does seem to be puting quite a bit of work into DivX (the codec) and XviD hasn't recieved many updates lately, although it did get faster GMC last week. Fact is that the rest of the world, including XviD are moving away from MPEG-4 Part 2 to MPEG-4 Part 10 and other newer technologies. So if DivX overtakes XviD, it won't matter anyway.
So when is Philips going to start pumping out the H264 players and will they handle high definition files?
By the time they release a stand-alone powerful enough to decode H.264, you may as well just get a Mac Mini or similar HTPC second-hand to be your main movie player... Or an X360 (once it's hacked to support Dolby Digital 5.1.)
Could you elaborate a little on your use of Nero Digital, please? For instance, do you have to buy the whole package (Nero 9) to get Nero Digital? Also, what do you mean by "put a DivX shell around it"? How exactly do you do this? If I sound ignorant it's because I am but I'm trying to get better.Originally Posted by Trident5
Convert MPEG-2 to avi./ QUERY...Best method please
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2010, 15:06 -
Can I convert an avi back into a DVD and restore original quality
By Vidonizer in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 15:32 -
Convert AVI to DVD best method advice required please
By vwgolfman in forum Video ConversionReplies: 7Last Post: 1st Apr 2008, 11:01 -
How Do I convert DVD Episodes in AVI in 350MB in highest quality posible
By Rockstar452 in forum DVD RippingReplies: 4Last Post: 29th Oct 2007, 04:39 -
Best way to convert avi to MPG DVD Compliant(highest quality)
By andre477 in forum Video ConversionReplies: 19Last Post: 25th May 2007, 05:59
