Hey guys this is my first shot at burning a cd.
I have an avi w/ac3 audio, its is a 25 fps PAL. When I encrpt using TMPGenc as a Pal it comes out perfect but won't play on my home DVD players b/c of area restrictions.
I then tried to encrpyt using Avi2Dvd and had it handle the PAl to NTSC conversion. I then get a copy I can play on my DVD players but the audio is out of sync.
I looked around at some other guides and they said that seperating audio from video might help. So now I'm left with a .mpv and a .ac3
So I try to use TMPGEnc Multiplex tool to join these 2 files together and I'm still getting out of sync audio.
If anyone has any suggestions on how to make this work they'd be much appreciated...
You might want to try ffmpeggui ... think that's the name of it .
Pal to ntsc conversion easy ...
Sound's like vbr audio is involved ... use virtualdub to load video , goto audio , set to full processing , set conversion to 48khz , then save out as wav .
From old test's here :
You now add this extracted wav by going to audio tab , sellect wav (locate new wav file that was created)
Go to audio compression , setup for mp3 ... around 32,000 ... something at 6kbps would be fine .
Go to video tab , set to direct stream copy .
Save avi as new name to another folder , and go .
If it dont work for you , you can just process each stream individually through ffmpeggui to required output .
It work's for me , but it could be a different case at your end .
Another way would be to frameserve the avi with new audio to bbmpeg , and encode to mpeg2 + mp2
Encode mp2 to ac3 using besweet .
As this is pal sourced , I would use ifoedit to do the basic authoring to vob title .
Now run ffmpeggui at it , and convert to ntsc .
This should take care of that audio slip , and the conversion . -
Check out this guide:
https://forum.videohelp.com/viewtopic.php?t=300144
This is a very good guide on converting PAL to NTSC...."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Convert NTSC AC3 (29.970) To PAL
By DeathStalker77 in forum AudioReplies: 0Last Post: 26th Apr 2010, 22:09 -
PAL AC3 to NTSC AC3
By USiT2009 in forum AudioReplies: 6Last Post: 6th Sep 2009, 17:55 -
problem with audio using besweet preset ntsc to pal
By Lynxer in forum AudioReplies: 0Last Post: 24th Aug 2008, 12:30 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
