are there any programs that do this. that is remove the vocals from a sound and leave the music.
i have sound forge. is it capable of doing it.
how do you do it
plz i need to know![]()
thanx
The vocal remover plugin from AnalogX works with Sound Forge as a DirectX plugin. It works on some tracks, doesn't work on others.
Short of getting the original masters and remixing, there is no way to complete get rid of vocals, and success varies from track to track.
You might want to read this thread. He is trying to do something slightly more complex than you, but it covers much the same ground. https://forum.videohelp.com/viewtopic.php?p=1512729#1512729Read my blog here.
that analogX is ignorance. Majority of the songs, i tried it on, the vocals were still there. Such songs were reggae and dancehall music
How's My English? -
All vocal removers work by polarizing one channel. This cancels out anything mixed in the center, which is where vocals are usually mixed. So how well it works, or whether it works at all, depends on how the vocals are mixed. Maybe vocals aren't typically mixed in center for reggae and dancehall music, I have no idea. But the point is that if something like AnalogX doesn't work than its not likely any other automated program will.
How do I edit the lyrics out of a song to make it an instrumental
By jbitakis in forum AudioReplies: 3Last Post: 25th Aug 2010, 05:32 -
How to create photomation?!?
By dabigwu in forum EditingReplies: 3Last Post: 2nd Mar 2010, 22:52 -
create slideshow
By shashgo in forum Newbie / General discussionsReplies: 27Last Post: 14th Aug 2008, 12:13 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
Looking for some good instrumental music that would be good for football.
By ingeborgdot in forum AudioReplies: 8Last Post: 26th Nov 2007, 22:18
