I don't have a Pro Logic system right now, and i want to check the results of some tests that i've been doing for 4:2 .
Does anyone know of some app to extract LCRS information ?
Thanks in advance.
From what ? Prologic was an analogue method, so there aren't discrete channels in the same sense as AC3. If you have just a stereo source - say a VHS tape - it will be difficult to extract the prologic information. If you have an AC3 file with prologic flags then is definately possible.
Read my blog here.
What i want, is to get a "PRO Logic information" in WAV format, from some mixings that i've been doing.
I have the material in WAV and AC3 2.0 also.
Is this possible ? -
The "Pro Logic" information is just stereo. There is nothing special in the audio, except it may have been tweaked to make the out of phase signals a little more pronounced, for better rear effects.
If I remember corrrectly, the original pro logic was pretty much just a Hafler setup + centre speaker connection, with a half-strength DolbyB noise reduction circuit stuck in so Dolby could claim license fees.
If you don't have a pro logic system, you might like to try wiring 4 speakers up in a "Hafler" configuration from a normal stereo output to get an idea of what's happening. -
If you have the stereo track, have a read of this article
http://en.wikipedia.org/wiki/Dolby_Pro_Logic#Dolby_Encoding_Matrices
At the bottom are the matrices used, so you can build the channels yourself with phase shifting.
This might also interest you
http://forum.doom9.org/showthread.php?s=&threadid=27936Read my blog here.
You can play the sound prologic sound with our DirectShow filter which has a built in DPLII decoder
and it will generate 6 channel stream...which is sent directly to the rendering device.
But I do not know if you
can capture it to 6 channel wave...
But at least you can perform some listenings.
What Is The Bost Most Lossless Format To Convert .mts Files To?
By JohnnyGalaga in forum Newbie / General discussionsReplies: 24Last Post: 10th Feb 2016, 20:27 -
Converting video to specific format, so hardware will decode
By numnum in forum Video ConversionReplies: 5Last Post: 11th Sep 2011, 15:23 -
Ripping Audio from DVD Best Format Lossless???
By matthewjohn23 in forum AudioReplies: 13Last Post: 1st Jan 2010, 17:42 -
"Where's progress app?" error when trying to decode VCD
By rossi in forum ffmpegX general discussionReplies: 8Last Post: 19th Aug 2008, 00:48 -
Trailers MOV format -- How to decode/demux/trancode to .MP4 ? [Solved]
By vhelp in forum Video ConversionReplies: 27Last Post: 21st Jun 2008, 14:00
