ok maybe someones experienced this and can help me out..
its nothing to do with my mouse messing up because it works perfectly fine at times, its just sometimes while browsing....my mouse cursor the speed of it, tremedously slows down, i have no idea what causes it or why it happens - and was wondering if someone maybe knew
for instance right now it's working normally the cursor moving around, with this page open/maximized....but if i minimize it and say go to my desktop to open a folder the whole speed of it just slows down tremedously (almost as if its wireless and im running out of batterys or some sort)
any ideas as to what it could be ?
it's no conversion....so moving you to our computer forum.
What kind of mouse do you have? If it is a ball mouse, have you removed the ball and cleanded out the conections. I found that every so often mine would clog up with gunk. If it is a laser mouse have you tried cleaning the laser underneath? What kind of mouse pad do you have? Is it worn or dirty?
Hope this helps, if not post back. -
it is laser and it's really weird, while browsing online like now it moves at normal speed and is fine..
but when i minimize and go to my desktop, the speed all of a sudden gets sluggish? i have no idea what it is
and i doubt it's anything to do with it being dirty or my mousepad cause like i said right now its working good until i minimize my browser and am on the desktop (or inside a folder) -
btw - it's a logitech mouse i have
i noticed it barely started working properly, when i opened my logitech mouse properties and ran through the settings and hit apply, i have no idea why i needed to do this..
and also i have my third mouse button (the weel) set to go 'back' a page, and that also periodically stops working -
too many applications open at one time and not enough RAM?
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
i think optical mouse devices need a special mouse pad or surface to work best. using any old surface or pad might give problems.
Originally Posted by isogonic
of paper. It also skips on some plywood. My mousepad has a semi-hard
plastic surface.
But his cursor only slows down occasionally. Might be a virus. He could
scan his PC at PCPitstop for viruses.
Just a thought!
Mouse problem = looking for new mouse.
By Stealth3si in forum ComputerReplies: 14Last Post: 12th Nov 2011, 04:25 -
System slows down after cloning
By mysts in forum ComputerReplies: 5Last Post: 2nd Jan 2011, 06:52 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
No subtitles or menu cursor on my PC
By jonghyunchung in forum SubtitleReplies: 6Last Post: 8th Feb 2009, 05:21 -
Laptop cursor moves on its own
By dimtim in forum ComputerReplies: 8Last Post: 1st Oct 2007, 11:07
