I'm trying to remove GMC and QPixel from some avi's. I've used all the front-end GUI's for VDubMod I could find. It's worked for some, but many of them displayed this error when muxing:
"The function DeleteComments was called on a stream[?] that hasn't been previously initialized with SetSource."
What can I do to solve this problem? Since I'm a real noob, I'm stuck relying on GUI's to get my work done, but the problem probably stems from my VDub.
I understand that part, but VirtualDub Mod itself is a 'GUI'. Which other ones are you using? And what format are you using? I'm guessing Divx.I'm trying to remove GMC and QPixel from some avi's.
I am also wondering what you are muxing? If you are working on the video, do you also have to convert the audio and mux it back in?
You might want to explain your process.
And welcome to our forums.
I had no idea, since I used AVI Recomp, StaxRip, and AutoGK, they all install VDubMod in thier directories, I thought that was the encoder itself.
I'm not quite sure how these GUIs work, but they all seem to create a temp folder, demux the audio and video, create a log with very vague entries (they only tell which pass has been completed, time, and whether it's muxing or demuxing), then mux it all back together.
Anyways, this error always seems to occur during the final phase of muxing (about 93%).
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 09:12 -
Problem with VirtualDubMod
By darkdream4 in forum Newbie / General discussionsReplies: 8Last Post: 4th Feb 2010, 03:41 -
Divx conversion error with VirtualDubMod
By newnews in forum Video ConversionReplies: 4Last Post: 8th Feb 2008, 16:15 -
How to set audio conversion settings in batch mode for VirtualDubMod?
By montango in forum Video ConversionReplies: 2Last Post: 14th Jan 2008, 04:56 -
VirtualDubMod RMVB conversion problem
By pchan in forum Video ConversionReplies: 7Last Post: 22nd Nov 2007, 19:39
