Has anyone ever gotten any sort of explanation as to why DVD recorders generally record with 256 Kbps audio (some do 384 Kbps in higher quality modes) when the standard on commercial DVDs is generally 192 Kbps for 2 channel audio?
Thanks.
They're not all that way--my Pioneer recorder does 192kbps.
It's all a matter of what the engineers considered to be adequate quality, given the A/D and encoding chips/algorithms used. Some want to err on the high side (giving more priority to audio quality), some want to err on the low side (giving priority to video quality/playlength).
Scott -
My Pioneer DVD recorder (model DVR-531H-s) does 2.0 AC-3 at 256kbps
Not sure why the DVD recorder maker's went with 256kbps vs. 192kbps other than they thought the extra bitrate was needed ... maybe since the AC-3 is done "on-the-fly"? Maybe because the quality level of audio is not as good or as "clean" as commercially produced audio? Those are only a guess though as I've never really read anything definative about why they use 256kbps.
Also I should point out that I have seen some commercial DVD discs with 2.0 AC-3 at 224kbps and once in a while even at 256kbps although yes it is true that most seem to use 192kbps.
The BBC also uses 256kbps for their TV audio via satellite & DTT - it just keeps the quality up in this age of so called CD Quality 128k encodes!
DTS 15xx kbps to DTS 768 kbps and tsMuxeR question.
By Jared_ in forum AudioReplies: 0Last Post: 1st Jun 2009, 10:46 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 08:57 -
iPod classic limit for AAC NOT 160 kbps! Supports 320 kbps!
By FallenAngelII in forum AudioReplies: 1Last Post: 29th Dec 2007, 13:14 -
Convert .ac3 (384 Kbps) to Dolby 5.1 (448 Kbps) ????
By christopheramos in forum AudioReplies: 6Last Post: 11th Jul 2007, 01:35
