I try to use some differents players for playback ( normally, I use PowerDVD, my favorite one) them and see what does it happen.In attempting to play (multiples) DVD (s) or single (s) dvd (s) files ripped to my HD, I received this notification:
Error Code: 8004027B
DVD-Video playback graph could not be built due to insufficient decoders.
MPC crash and the only one which can reproduce the files are ZoomPlayer.
Well, I reinstall Power DVD and the images works normally, finally.
But, despite of that, the sound are very terrible now: video play nice, but the sound are no good. It seems that sound fails in playing after some miliseconds, trembling, very similar a "cough" or "choking".
More strange: when I open the single files using Windows Media Player version 6.4.09.1128 ( i've instaled MPEG decoder too, like Dscaler MPEG Filters), the video and the sound are reproduced perfectly.
Does anybody knows what is going on here with the sound and my player (s)?
How is this situation could be remedied?
PS 1: if I'm have some problem with my sound/video Directshow Filters / codecs, how to solve it? How to fix all the conflicts?
PS 2: ffdshow doens't work on my system too. It crashes when I activate it to decode some file types, like MPG-2.
Thanks for help.
devil (johner)
sounds like you have too many codecs installed and they are having conflicts. You can use a program such as codec sniper to check your codecs. Your best bet, would be to uninstall/remove all of your software/codecs and only reinstall what you need.
Google is your Friend
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 14:53 -
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 13:27 -
VOB Error While Using Power DVD 10
By skorpinok in forum DVD RippingReplies: 3Last Post: 24th Aug 2010, 14:27 -
Unhandled exception error mencoder convert opendivx video - How to solve?
By melaos in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 04:43 -
Can you solve my choppy video problem?
By imrealdumb in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2009, 20:44
