I´m using DVDlab Pro for authoring and When I burn the DVD the some chapters get froze,
*I use WinAVIVideoConverter for converting the AVI file to DVD
* Voedit for demux the DVD
* Then DVBlab pro for menus and Subtitles
I used a converter for AVI to video (*.m2v) and audio (*.ac3) directly but I can´t remember what It was, anybody knows one?
So it's not actually a problem with DVD Lab Pro, but a problem with your memory ?
Perhaps next time you could use a better subject title for your post.
Tmpgenc with the AC3 plugin should be able to output elementary streams. Certainly anything (except perhaps DVD Santa) is better than WinAVI.Read my blog here.
DVDLab Pro problem, menu background colors change when rendered.
By PSPGamer in forum DVD RippingReplies: 19Last Post: 2nd Mar 2011, 21:42 -
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 20:21 -
Weird problem importing son format subtitles from TS in DVDLab Pro
By Talayero in forum SubtitleReplies: 1Last Post: 15th Apr 2009, 05:47 -
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 10:18 -
First Play problem in DVDLab PRO
By grzegorz in forum Authoring (DVD)Replies: 5Last Post: 11th Apr 2008, 05:43
