I made a copy (CD to CD copy) of a VCD I bought on a CD-R disc. But I wasn't able to play it on the standalone home DVD/VCD player--it said "disc format not supported" when I put it in. The copy could only play on my computer.
Besides getting a DVD/VCD player that has CD-R support, how can I copy a VCD and have it play on a standalone DVD/VCD player, just like the original does?
Please reply.
if the hardware can't read/play it, it can't be done, that simple. changing firmware/hardware is the only way but too much trouble, better off getting a new DVD player.
Yes, Condone is right, you should get a DVD player that not only will read CDR/CDRW, but make sure it can read VCD & SVCD format. Check the compatiblity list.
I would prefer downloading CloneCD to make (CD to CD) copies. It does a better job of copying VCD's & Music CD's. -
If you are having a problem with CD-R media on your player, you can often still get some brands to work. However, you may have to experiment with different brands to find one that does. CD-RW often works better in these cases.
Regards.
Michael Tam
w: Morsels of Evidence
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 03:09 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15
