I just bought an ATI Radeon 9200se. When I play an .avi with the proper .srt file, the playback is upsidedown, doubled and only on the top half of the player. With my previous video card this did not happen. When I get rid of the .srt (rename it to something else), playback resumes a normal appearance. I have VMR9 (renderless) enabled and DirectVobSub installed.
Results 1 to 11 of 11
Try a different media player first. The freeware VLC Media Player is a good test as it uses it's own codecs and works well with subtitles. It sounds like a codec problem. If it plays OK there, MPC may be messed up or you have something wrong with your codecs. Try deleting MPC and then reinstall.
Try right-clicking the video and then go Subs->Uncheck "Enabled". It's probably the double subs that are screwing you up.
Double subs were enabled, so I unchecked "Enabled" with no change except the subs on the bottom of the screen (being properly displayed) went away. VLC player played it fine but the Subs weren't displayed. I uninstalled DirectVobSub and now the video is playing fine with subtitles. Normally the "Play > Subtitles" menu is grayed out, and now it isn't for some reason. And when I had DirectVobSub installed before (with my previous video card), I had no problems with playback. I am not understanding why things sometime work and sometimes don't. I do like VLC player, but could someone tell me how to enable subs in it?
VLC should have the subtitle display set by default. If you go to 'Preferences>Input' you should see a check box for that, along with a box to set which subtitle stream to use if you have multiple streams. You can also adjust the subtitle delay in 'Hot Keys>Advanced'.
It's Preferences / Input / Other Codecs / Subtitles
And Preferences / Interface / Hotkeys / Hotkey settings / ...
You also have to look under
Preferences / Video / OSD/Subtitles
MPC-HC playback issue
By leghorn in forum Software PlayingReplies: 2Last Post: 13th Feb 2011, 11:52 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 11:52 -
Setting up MPC HC for video playback
By Mylo in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2009, 09:29 -
MPC-HC and MKV playback
By tiger6969 in forum Media Center PC / MediaCentersReplies: 6Last Post: 28th Dec 2008, 18:58 -
MPC playback problem
By ecc in forum Software PlayingReplies: 1Last Post: 14th Jun 2007, 12:24
