Hi..I'm running an MSI-DR8A dual format Rewriter in XP Home (SP2) which has just started acting up after giving zero problems. I use Roxio's Easy CD Creator for burning.
When I insert DVD film etc, PowerDVD software is normally engaged automatically.
However, this has stopped happening...the green light comes on for a while (presumably reading the disc), then goes out.
I've tried cleaning the laser but this doesn't help.
The drive plays CD-R's and CD-RW's and records to these formats...so CD music is clearly being picked up.
My system is kept very clean and after running a number of precautionary checks for adware/malware etc, nothing seems amiss...
I've also tried disabling the drive through Device Manager, then re-enabling...but no luck.
Is the drive's laser at fault? I've checked for firmware from MSI and have downloaded a zip file...but I'm a bit reluctant to 'flash' an update...The instructions for doing so from MSI leave me scratching my head...
I'd appreciate any help
Many thanks
Well, DVD burners do wear out or break. If you get nowhere, you might try the firmware upgrade. But those are usually to speed up reading or to enable writing to newer brand discs or just to enable all regions.
Typically a DVD laser and a CD laser are separate in a DVD drive. One can quit and the other still work. You've tried cleaning, that is the first thing to try. If the problem still exists with commercial DVDs, you may have a problem.
Don't give up just yet, but a failing drive is one possibility.With the prices of burners at present, I would at least think about changing out the unit.
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 12:18 -
Laptop rebooting during burning with Pioneer DVD-RW DVRKD08RS rewriter
By rock_king_my in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Sep 2009, 04:04 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
Samsung Writemaster DVD Rewriter & Ripping DVDs
By rock_king_my in forum DVD RippingReplies: 1Last Post: 7th Dec 2007, 00:47 -
Adobe Encore DVD disc reading issues in DVD Duplicator
By Mergebow in forum DVD & Blu-ray WritersReplies: 0Last Post: 2nd Jul 2007, 15:49
