I lost the compressor option and the mpeg2 option for FCP (I upgraded OS to Tiger and I upgrade QT to 7.03 (which I remember un-doing a year ago because it didn't have mpeg2), I think?
Anyway, now what do I do please...do I "buy/get a QT plugin?" or compressor or a 3rd party, or downgrade QT to my old version or what? FCP 4.5 btw.
Mark
(PS - I'm searching all over apple.com and they keep referring to mpeg2 "players" not for making DVD's - again, though, it could be staring me in the face and I woudn't know it...all I know is I buy 2 upgrades (QT and Tiger) and now I can't burn a DVD)
is this what I should buy
http://www.apple.com/quicktime/mpeg2/
BTW - what took away Compressor (Tiger or QT7 upgrade?)
Results 1 to 9 of 9
Try re-installing Compressor and FCP from Disc.
I did this after upgrading to Tiger from 10.3.9,
and it put everything back, except for the Plug-in.
Luckily, I remembered that when QT 6.52 came out,
you had to upgrade the MPEG-2 component for that,
but it was FREE to PAID users of 6.03 or earlier...
I checked my email, and had the link for it.
I re-downloaded it, and it works like a charm
for QT 7.04."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I'm legal with FCP but have no discs.
Therefore, is my path of least resistance to buy the "plug-in" for QT 7?
Never bought a plugin before, cant find it on Apple.com (I dont speak good mac, just converted from years of PC.....
How do I get the mpeg2 through QT....(I'll buy it - although I'm sure you've heard it before that the only bad thing about macs is that an upgrade is often a downgrade....I had it with 6.x and lost it with 7.x,(right?).....
Or, is there a third party?
Or, should I go back to previous version of QT (which I did before, but can't remember how) - I had a mac guru who helped me then....he moved.
thanks,
Sorry if niave questions.
Mark -
QT 6.52 doesn't play well with OSX Tiger. So
no, you can't go back, unless you go back
down from OS X 10.4 to Panther 10.3.9.
If your legit, then you should have no problem buying from this page:
Apple QT 6.04 or later MPEG-2 Component. this will be your
simplest route.
Also, take the time and get and learn about this FREE piece of
software called Carbon Copy Cloner. Had you had used this,
you could have pulled a copy of the component from a backup
of your system."Everyone has to learn, so that they can one day teach."
Urban Mac User -
There is no longer an "Export to MPEG" option. It is all Compressor now.
Keeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
Your source for iMovie answers and what not! ;-) -
umm...I believe were talking about in FCP 4.5 ( HD)
when you do Export to Quicktime,
you can then select to MPEG-2,
Dan."Everyone has to learn, so that they can one day teach."
Urban Mac User -
DOH sorry!
s'ok, my friend.
Your more than helpful contributions more than
make up for
a slight fubar!
Urban Mac User
Best Export Method for FCP?
By Jeff_NJ in forum MacReplies: 1Last Post: 4th Nov 2011, 12:12 -
need to export for tv broadcast h.264 sd on fcp
By ericbphoto in forum Video ConversionReplies: 1Last Post: 22nd May 2009, 13:24 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 15:59 -
FCP Downconvert and Export 16:9 to Quicktime
By Jeff_NJ in forum MacReplies: 1Last Post: 24th Oct 2008, 11:45 -
Export to FCP Quicktime Movie
By James in HD in forum MacReplies: 2Last Post: 2nd Dec 2007, 08:43
