    Mar 2005
    Im trying to watch a movie but there is no audio, so i decided to use Gspot to see what codec is missing, but when i put in the movie into gspot it sais that there is a codec installed and it is called
    ac3 (0x2000) Dolby Laboratories, Inc-- (The following codec should be capable of processing this format: Nero Digital Audio Decoder- Direct Show was also able to find a codec to render it, the sound for this media clip should work fine.)
    But there is no sound in the movie.
    When i click render in Gspot this is what i got.
    Audio Decoder Nero Digital Audio Decoder
    Audio Renderer Default Direct Sound Device.
    Anyone have any idea what the problem is? Thank you for your time and help guys I appreciate it.
    Dec 2004
    Australia
    Nero tends to block their filters from working in 3rd party apps. Try AC3Filter or ffdshow to decode.
    Mar 2005
    THANK YOU ILL GIVE IT A SHOT
    Mar 2005
    Your the man, SOUND ON
    thank uuuuu
