My car has a DVD-Audio player so I was wondering if it is possible to author a DVD-A (DVD Audio) disk. I found one program but it only accepts WAV files. All of my music are in the MP3 format, so I am looking for software that can convert and burn the MP3 files on to a DVD and make it an DVD-A.
Apparently DVD-A disk may fit up to 6 CDs into a DVD-A disk. It would only be Stereo, but still it is much better then one CD.
http://www.audio-dvd-creator.com/download.htm
used this prog for several years now easy/makes perfect dvd audio even 5:1 -
Thanks.
I found that app and another one yesterday, but I think you are confusing the Audio DVD with DVD Audio.
It even states in the home page of the Audio DVD Creator.
"Please note: Audio DVD should not be confused with DVD-Audio, for which you need a special player and discs!"
I am looking for DVD-Audio authoring.
Some think like this but for MP3s - http://www.cirlinca.com/ . This one works only with WAV files -
delius,
That's NOT the kind of disc suppafreak is talking about. Notice that on the Audio-DVD-Creator website, it saysThis means it's making a "DVD-Video" type disc, not a "DVD-Audio" type disc, whether they call it that or not (for marketing purposes) is beside the point.play it on any DVD player since it's DVD-Video compliant
suppafreak,
There are only a few apps that can create DVD-Audio type discs. Most are expensive. Minnetonka's discWelder series is probably the most popular--they have a $99, $495 and a $2995 version. There website is HERE.
Alternately, there is a freeware DVD-Audio Tools site--HERE, but it hasn't been updated recently. Also, not as easy/straightforward to author.
Once you've authored the AUDIO_TS files/ISO, you would use a DVD disc burning app (like Nero, etc).
Nonetheless, you're going to have to convert those mp3's to WAV anyway. DVD-Audio expects LPCM, so it couldn't use mp3 anyway without converting 1st (whether in the program or before). Remember, the whole thing about DVD-Audio is quality.
If you can't get your original WAV versions of those clips, there are plenty of tools <-- here and on the net that'll convert mp3 to WAV.
HTH,
Creating video from images WITH audio
By boyer in forum Video ConversionReplies: 13Last Post: 3rd Mar 2012, 02:01 -
creating an audio track for a custom DVD.
By fred3f in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2011, 05:42 -
Creating audio DVD advice please
By ozbrit in forum AudioReplies: 5Last Post: 5th Jan 2011, 08:36 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
Creating a DVD from a MKV file and retaining all the audio tracks
By TioSolid in forum Video ConversionReplies: 7Last Post: 8th Aug 2008, 07:06
