I use this to convert my divx files to dvd files.
It works great when I simply have one added to the List and converts it great.
However I dont know why, but when I have more than one on the List, just as it starts to convertr the second one, the program crashes.
It has even done so when each of the files has been created by the name group.
Can anyone help me?
Also I have a 1.8Ghz and 2GB Memory System.
Does it do much if I change the encoding conversion priority to Time Critical?
I used to use dvdsanta all the time with no problem and stopped because everything converted out of Sync.
Also used Win Avi for those which wouldnt convert properlew, now this doesnt work and converts it with problems on the Video like not converted properley, it asks to check if i have quiktime version 4.5 installed.
ipresumed it meant quicktime, installed it but made no difference.
So really it cut down the programs i could use and is very limiting when divxtodvd wont convert more than one file per dvd.
Hope you can help or even recommend another All In One converter
are you using the latest free version of divxtodvd? or upgraded to convertxtodvd?
Something wrong with DivxToDVD download here?
By gastrof in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2011, 10:46 -
The problem with the SubtitleCreator program in Windows seven
By offlinebaz in forum SubtitleReplies: 2Last Post: 25th Dec 2010, 10:57 -
Does DivXToDVD's "back-up" function copy or re-encode or both?
By moviebuff2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2007, 17:00 -
DivXToDVD Ballooned My VOB Files
By moviebuff2 in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2007, 22:12 -
divxtodvd problem
By BPH2002 in forum Newbie / General discussionsReplies: 31Last Post: 27th Jun 2007, 08:17
