Hi, recently when i try encoding from AVi to mpeg2, i'm getting this problem
"Invalid sample format (error code 0x80048002)"
that's the literal error msg problem, i read in this forum that someone suggested using AVI synth, but i can't get it to solve this problem... other solutions involve TMPGEnc 2.5 Plus which i don't have..
is there any other solution to this? or should i go looking for another encoder?
If i do go looking for another encoder, could someone recommend me a more stable yet not too simple encoder? (i want to be able to fix my own bitrate)
thx in advance
what is your source video and audio? just avi doesn't say anything, identify with for example avi2clipboard.
I believe that disabling audio in Xpress and processing only the video will solve this. You can work the audio separately, for instance demuxing it with VirtualDubMod as AC3, and later use this AC3 as audio source into your authoring app.
thx. i'll give it a shot
kinda wish everything can be done with 1 software though
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 06:10 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 05:27 -
Problem with TMPGEnc Xpress 4
By milindb1 in forum Video ConversionReplies: 1Last Post: 20th Aug 2008, 03:43 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
TMPGEnc 3.0 Xpress problem
By adamthered in forum Video ConversionReplies: 2Last Post: 7th Jul 2007, 17:22
