I have yet to find a way to convert .flv's from myspace to anything I have tried Riva and SUPER but both give errors can anyone offer any help. Thanks
here is an example flv
http://content.movies.cdn.myspace.com/0005555/33/36/555526333.flv
Results 1 to 17 of 17
http://celticdruid.no-ip.com/xvid/ under external mpc filters. Should support flv's containing VP62 with alpha now to.
Once you unzip the FLVSplitter.7z file to the FLVSplitter.ax file, then what?
And how do you register it, Brother Maynard? Enlighten us with more precise instructions.
I'm sure if you searched you could find more info.
Yep.
https://forum.videohelp.com/viewtopic.php?p=1484385&highlight=register+filter#1484385 -
Your search was too specific. Registering one directshow filter is the same as any other.
If you can't convert Myspace flv-videos, is there at least any player with which yon can control their brightness? Many Myspace videos are so dark that you can hardly see anything at all.
Here's how to register the file. Start button -> Run. Type "regsvr32 flvsplitter.ax" without quotes. btw p_l your avatar reminds me of pia in the getpaidforum.
Thanks for the instructions.
I'm not pia, though, and I beat him in choosing that avatar by 5 days, back in 2002. :P -
I can't download your flv file.
I have a software that can convert flv with vp6 to avi. -
Damn!!! $100 for that software.
Snagit does a hell of alot more than that for $40 and the demo is fully funtional, unlike this one that puts a huge watermark over the center of the clip.
BTW, that's all this program is. A screen capture software, not a vp6 flv converter.
It plays the file in it's own player and you click a capture button to capture the clip and click finish to stop capture. Then it saves to whatever you have as preset. It did seem to pick the right framerate though which other programs I tried can't seem to do.
I've come to the conclusion that you CANNOT convert vp6 flv to AVI or any other format.
problems converting MOV -> FLV
By dannyboy2090 in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2010, 13:50 -
Problems converting FLV
By am_dew in forum Video ConversionReplies: 8Last Post: 15th Jul 2010, 00:02 -
Having problems converting flv to MP4
By Norkusa in forum ffmpegX general discussionReplies: 5Last Post: 16th Aug 2009, 21:54 -
Converting MOV to FLV - codec problems
By communique in forum ffmpegX general discussionReplies: 5Last Post: 13th Jun 2008, 15:58 -
problems converting to flv
By devriesfilms in forum MacReplies: 7Last Post: 2nd Apr 2008, 13:36
