Not sure where to post this, so I apologise if its in the wrong forum.
But I am at my wits end with this, im thoroughly peed off
Basically, no matter what I export as in Adobe Premier Pro 1.5 it 'stretches' the image. Allow me to explain:
This is my original ratio footage in Premier. You'l notice its 16:9
Now here are my settings to convert it to Quicktime:
But this is what it looks like:
Notice that its squashed.
If I try a different method and export it as an avi...its squashed again!
Back in the day, when I had Premier 6. I had no problems in exporting files to Quicktime format but with Premier Pro 1.5 I keep on having this problem.
The only way around the issue is to export as 'SQUARE PIXELS 1:1' But this puts black bars on the top and bottom.
There has to be something im doing wrong. If someone could help me I would be grateful
you seem to be a bit confused about aspect ratios and pixels. if you export your video as 720x576 it is 4:3 and will fill a normal tv screen with what is in your first pic. in order to be kept as 16x9 and not stretched vertically you need to add black bars top and bottom to fill 720x576 or encode as about 720x400.
ahh, thanks! I have actually tried the other resolution in the past 720x405 but it still didnt work. With your help mate, Iv converted it to square pixels and done this and now it works!
Originally Posted by Sober
You need to explain what you intend to do with this file. If you use 720x405 lines, you have cut vertical resolution to 70%. Why do that? -
But I intent to export this for the web and so cant afford it to be squashed.
I'l export it like i originally did and copy it to DVD...then see if it plays ok on the TV.
But by exporting it as 720x405 square pixels. It keeps the same aspect ratio and no cropping occurs....I can vouch for that by these screenshots i have here. -
QuickTime Pro exporting image sequence with the frames in the wrong order?
By adam-tl in forum Video ConversionReplies: 2Last Post: 29th Nov 2011, 15:55 -
Premier Pro CS3 exporting problem
By SB4 in forum EditingReplies: 0Last Post: 13th Dec 2010, 09:50 -
Premier CS4 exporting issue
By Jonza in forum EditingReplies: 2Last Post: 3rd Feb 2010, 04:08 -
Exporting HD in Premier Pro
By videopetur in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Jan 2009, 15:20 -
Codec choices for editing and exporting in Premier
By nhart1001 in forum Video ConversionReplies: 6Last Post: 8th Sep 2008, 18:01
