I recently completed creating a DVD, and I am using DVD Studio Pro to burn the build files. However, I want to be able to give the build files (VIDEO_TS goodies, you know) to some one else so they can burn DVDs at their leisure. They are on a PC. Should I simply burn the VIDEO_TS folder onto a data DVD? Then they can use these files to burn DVDs on their own PC.
Yah? Nah?
(Is Nero still the standard PC burning app? Anyone know of any other options offhand?)
Thanks a lot..
Burning the VIDEO_TS folder onto a UDF data DVD is the very definition of making a homebrew DVD Video. Just burn it and send the guy a disc.
Including the "build files" like the PAR folders, the .lay files etc will mean zip to the PC ... DVD Studio Pro uses those files, and it isnt available for Windows PCs...
Transferring files between 2 PC's using ieee
By dbanimal in forum ComputerReplies: 22Last Post: 30th Dec 2009, 03:27 -
8 hours of MiniDV tape to DVD. Least painful method of transferring?
By Simmster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Nov 2009, 05:30 -
Trouble Transferring Files From DVD-R to Computer
By meadowburke in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 12th May 2009, 15:14 -
Encoding .MKV Files to DVD: Best Method?
By Alexius in forum MacReplies: 1Last Post: 8th Jul 2008, 01:05 -
Transferring Music Files
By mccoady in forum ComputerReplies: 5Last Post: 14th May 2008, 12:41
